motor mounts bucking at low speed?
i got a 93 coupe turbo.. it has both front torque mounts and rear mount is good. it was bucking like crazy between 5-10 mph when i slow down . motor was jerking around and making me look like i cant drive. i put the energy suspension inserts in both front mounts and the rear . its better but still does it. does anyone else have this problem? all the mounts are tight too.. i hate it. my crx was tight as can be but this car bucks .. both side mounts are ok too. 5 spd single cam
i understand that. im saying get them also in the torque mounts down low. they tend to tear and they do exactly what they say they do (control torque). that torque will cause your engine to "buck". as an aside, what clutch are you running?
there are five total mounts. to top mounts that are large and up front. two torque mounts that are small and down low. and one large rear mount
i have them in the torque mounts. only ones without the inserts are te big side mounts. the bottom two torque mounts have the inserts . ACT clutch.
spoon makes a engine damper and i use it and it stopped a lot of shaking that i had they might help http://www.aj-racing.com/catalog/pro...productid=1326
crxsiperf
04-08-2006 08:01 PM
