What should i do??
Old Apr 13, 2003 | 07:11 PM
SjCiViCHB's Avatar
Default What should i do??
I just bought a skunk2 im (Thanks ShiftHard) for my B18c1 and i was wondering what ecu i should use. Oh, and i dont have any real mods, just Intake and Exhaust. I bought the manifold cause i messed up the stock manifold. While removing the stock manifold i broke the knock sensor, well just the part where the connector goes in. Well my question is, should i just get a new knock sensor and keep using the p72 with the skunk2 mani? or should i not even worry about the sensor, and just get a chipped p28??
so whatchu guys think? chipped p28 or stock p72? if chipped p28 what program i was thinkin skunk2 since i plan on getting skunk2 camshafts and valvetrain soon.
Old Apr 14, 2003 | 02:22 AM
SjCiViCHB's Avatar
Default Re: What should i do?? (SjCiViCHB)
ttt
Old Apr 14, 2003 | 08:06 AM
hriday2's Avatar
get a chipped p28 and remove the knock sensor. I don't think you'll need to change the ecu if you just replace te knock sensor. Also the new intake manifold shouldn't require any new ecu tuning.
Old Apr 14, 2003 | 01:56 PM
SjCiViCHB's Avatar
Default Re: What should i do?? (hriday2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hriday2 &raquo;</TD></TR><TR><TD CLASS="quote">get a chipped p28 and remove the knock sensor. I don't think you'll need to change the ecu if you just replace te knock sensor. Also the new intake manifold shouldn't require any new ecu tuning. </TD></TR></TABLE>
So i dont even have to have a knock sensor in if i use the p28?
Old Apr 14, 2003 | 05:25 PM
SjCiViCHB's Avatar
up.
DO i have to have a knocksensor in place of where its supposed to go? how bad will it be if i run without the knocksensor and using my p72 still? its goign to take about a week till i get the p28.
Old Apr 14, 2003 | 05:40 PM
poison's Avatar
I would obtain a chipped P28. And the P28 does not have a pin-out for the knock sensor, therefore, it'll do no good with having one
The P72 will work in the mean time though.
Old Apr 14, 2003 | 06:23 PM
SjCiViCHB's Avatar
Default Re: (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">I would obtain a chipped P28. And the P28 does not have a pin-out for the knock sensor, therefore, it'll do no good with having one
The P72 will work in the mean time though.</TD></TR></TABLE>
So even if i dont have the knock sensor in place on the head, it wouldnt leak anything and will be fine?
Old Apr 14, 2003 | 07:02 PM
VTECVillain's Avatar
Default Re: (SjCiViCHB)
The P28 is a good choice for a single stage manifold like the Skunk2 that you have. BUT with the stock GSR cams it's not a very good choice. The P28 has a higher VTEC point and by that time you're in between the powerband of the stock GSR VTEC and the IAB stage. I would stick with the P72 until you get some cams - ITR/CTR would be a good choice.
Old Apr 14, 2003 | 07:15 PM
poison's Avatar
Default Re: (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">The P28 is a good choice for a single stage manifold like the Skunk2 that you have. BUT with the stock GSR cams it's not a very good choice. The P28 has a higher VTEC point and by that time you're in between the powerband of the stock GSR VTEC and the IAB stage. I would stick with the P72 until you get some cams - ITR/CTR would be a good choice.</TD></TR></TABLE>
damn good advice
couldn't have said it better myself
Old Apr 14, 2003 | 07:22 PM
SjCiViCHB's Avatar
damm...so i should just buy a new knocksensor and keep using the p72 till i get my cams huh? Thanks alot guys. Oh, what is the vtec engagement and redline for a stock p72 anyways if i may ask?
cthan3o3
Aug 10, 2005 10:21 AM
Jmunk
Feb 23, 2005 04:54 AM
TABIAS
Jul 14, 2004 10:37 PM
1.8T_EG
May 13, 2003 03:21 PM
95c1v1cs1
Mar 17, 2003 05:56 AM
