What engine should i get?
Old May 7, 2001 | 07:01 PM
CivicAlpha's Avatar
New User
Default What engine should i get?
I'm in search for an engine for my car. I have a 96 Civic HB. so what engine should i get? give me details and why. Thanx
Old May 7, 2001 | 10:54 PM
dustin's Avatar
Default Re: What engine should i get? (CivicAlpha)
b18c1... affordable... fits right in... and fun to turbo
Dustin
Old May 8, 2001 | 08:39 AM
eg6ajk's Avatar
b18c or b18c5
stay away from b16b as cool as it sounds its simply over priced b16a......for the same price you can have a ITR which will be at least .5sec quicker in 1/4mile......
Old May 9, 2001 | 09:20 AM
92sleepR's Avatar
New User
Go CR-VTEC. The conversion has been done sucessfully and is well documented. For the $$$ you would spend on a B18C5 you get 2 liters worth of torque.
It's what I plan to do this winter.
Mike
Old May 9, 2001 | 10:44 AM
Mike D's Avatar
Default Re: What engine should i get? (92sleepR)
me? i would go ls turbo/b20 turbo. it all depends on your plans. An ls can be had for cheap form looking around. Do a custom turbo and you will have a sweet engine.
Plus with a few internal mods you can get a lot out of that engine....i.e new rods and and pistons(not sure how much boost teh stock internals can take).
Old May 9, 2001 | 07:46 PM
maxxdout's Avatar
Default Re: What engine should i get? (hennessey)
B18B, easy to get your hands on, cheap, cheap and cheap. Good power , great at low end. Even stock great at low end. not to bad for build up. Its possible to go CRVTEC or LS-VTEC. Just a decent cheap way to start.
Old May 9, 2001 | 10:29 PM
raene's Avatar
I second the motion for B18C1. What's the world's most supported engine?? Integra GSR... so why not tap right into all that aftermarket support??
Old May 10, 2001 | 08:07 AM
Yellow Dragon's Avatar
B18C1. Because I said so.
Old May 10, 2001 | 10:06 AM
DragII's Avatar
Default Re: What engine should i get? (Yellow Dragon)
I don't know man..make up your own mind
Old May 13, 2001 | 09:50 PM
CivicAlpha's Avatar
New User
Default Re: What engine should i get? (DragIIcivic)
I just thought of something, Hows the idea of a B16A stroking to 1.8 and turbo charging it. If i stroke it to 1.8..is that the same as the B18C1? if its different, how many hp do you think it will be? Let me know if this is a good idea. thanx
Old May 13, 2001 | 11:15 PM
5gen-hybrid's Avatar
New User
b18c1 best priced engine good for n/a and turbo. don't get a b18c5 or b16b unless you have some money to waste and you have something to prove.
Old May 14, 2001 | 03:18 PM
Balrog's Avatar
New User
Default Re: What engine should i get? (hybridxcivic)
stroke the b18c1 out to 2.1, its half of what a turbo will be and there so much you can do with the head while its off. *shrug*
Old May 14, 2001 | 04:03 PM
LS-T's Avatar
New User
b18c5....its fast and rare
Old May 15, 2001 | 08:36 AM
CivicAlpha's Avatar
New User
Default Re: What engine should i get? (Armani692)
So is stroking an engine a good idea? I don't know much about stroking. Does it shorten the life of the engine? What outcome does it have? So..is the idea of stroking a B16 to 1.8 the same as B18? I still need to know about some details. thanx
Old May 15, 2001 | 09:16 AM
raene's Avatar
I think the actual deck height is taller on the 1.8L, so it's likely that a B16 stroked to 1.8 would have different characteristics than the 1.8 by itself. Plus, it's cheaper to buy the 1.8 than get a JUN stroker kit . Plus, remember the B18C has those funky intake manifold runners that the B16A doesn't.
Old May 15, 2001 | 01:08 PM
Balrog's Avatar
New User
strokeing a motor is essentially rebuilding it from scratch, it's a whole new motor. no wall wear(bored and sleeved). you buy a kit, it will all be new. so to ask about engine life? it'll be like haveing a H22 that's brand spank'n new(with more torque) without all the weight. if you want 1.8, just get an LS or a GSR, i would think it to be to much trouble(even know it seems to be cheaper i.e.EM) to stroke a B16 to 1.8.
Lamska
May 29, 2006 11:20 AM
b16greenmachine
Dec 25, 2005 06:40 PM
civicdxcpe
Sep 3, 2004 11:54 AM
RedHatch
Sep 29, 2002 06:53 PM
turbopanda
Nov 10, 2001 01:24 AM
