which engine should I turbocharge next?
Old Nov 4, 2001 | 11:55 AM
turbopanda's Avatar
Default which engine should I turbocharge next?
OK this has been on my mind for quite some time now. I can't make up my mind on which engine I should drop into my car next. First it was a B16A (cheap), then I changed my mind to a B18C (more power), then I got this crazy thought of doing a CRVTEC turbo, then thought of doing a non-vtec B18B or B20B. ARGH!!
ok anyway, i'm looking into doing something that will still give me daily driveability yet be able to produce 300+ HP at the wheels. I want something that won't require me to change rods and pistons etc.. something that requires minimum changes in the engine's internals to produce satisfying power. someone convince me of which engine to play with!!
Oh yeah, my car is an EK sedan. Not a coupe. A sedan.
Old Nov 4, 2001 | 12:17 PM
immortal's Avatar
Banned
Default Re: which engine should I turbocharge next? (nathan's boosted civic)
B18C1
There truly isnt anything better stock....
High revving, more displacement than a B16
Perfect 10:1 Ratio for Street boost
Old Nov 4, 2001 | 01:25 PM
DR. ON POINT's Avatar
Banned
Default Re: which engine should I turbocharge next? (immortal)
if u want soemthing cheap yet u can get a lot of power I would get a b20 or a ls motor. I am getting a ls motor. I have seen some good *** times with stock internals and a turbo kit.
LS boosted=
Old Nov 4, 2001 | 01:32 PM
jinxproof99's Avatar
New User
stock gsr block and an inline pro headgasket. WAY more relable than a turboed crvtec.
Old Nov 4, 2001 | 02:22 PM
JM Performance's Avatar
Default Re: which engine should I turbocharge next? (jinxproof99)
I'd go w/ a b18b. The money you save over the b18c can go towards better uses.
Old Nov 4, 2001 | 06:22 PM
D-Man's Avatar
Default Re: which engine should I turbocharge next? (00SilverLS)
F the B series,in a 96 and up,,you should go with an H22 or H23 with H22 head
Old Nov 4, 2001 | 06:29 PM
TurboInteg95's Avatar
Default Re: which engine should I turbocharge next? (D-Man)
pretty much no. it will handle like ***, and be hard to work on.
Old Nov 4, 2001 | 06:34 PM
Etylorcen's Avatar
Default Re: which engine should I turbocharge next? (TurboInteg95)
B18b is a cheap motor that can handle lots of boost stock. Mine is running great.
Old Nov 4, 2001 | 07:52 PM
Liltrix's Avatar
B18C1 Block with a B16 Head
Old Nov 5, 2001 | 01:45 PM
01geeser's Avatar
New User
h series in these cars are ***, youll understeer into a wall. b18c is the way to go
Old Nov 5, 2001 | 01:58 PM
4dGSR at work's Avatar
Default Re: which engine should I turbocharge next? (01geeser)
the crv
b20
pretty cheap too
rods pistons the works but you know that!!!
oh and the engine ... displacement!!!! you know thats what its about
Old Nov 6, 2001 | 10:42 AM
Default Re: which engine should I turbocharge next? (4dGSR at work)
quick question for anyone
what does a crv engine go for??$$$$$$$$
stock block should take about 13psi max....thats some good gains to be had.
a nice obd 1 b20 ahhhhhh!
ls tranny
port out that b20
straight t4 or t61
a nice standalone system
could be fun and cheaper then a gsr(b18c1...we all know)
Old Nov 6, 2001 | 11:06 AM
New User
ls tranny
port out that b20
straight t4 or t61
i picked up one for $1000....jdm w/ under 50,000 miles.
Old Nov 10, 2001 | 01:24 AM
turbopanda's Avatar
I'm probably going to do the B18C, because if I ever sell the car, I'll remove the turbo and make it NA. If it was a B18B or a B20B sitting inside, those things would run like **** without the VTEC (or should I say Boost for this matter )..
why don't I sell the car with the turbo inside you ask? Because NA engines with turbo drop the value of the car so much that its not funny. They think you're selling the car because its about to blow up.
dvs's
Feb 4, 2007 04:58 PM
OneSickJDMBB6
May 4, 2005 07:59 AM
mz3bo
Oct 16, 2002 08:41 AM
shaolin9
10
Aug 18, 2001 09:39 AM
CivicAlpha
May 15, 2001 01:08 PM
