vtec press.switch?
Old Dec 11, 2004 | 12:43 AM
jess press's Avatar
Default vtec press.switch?
Anybody know where the vtec pressure switch is on a b18c and besides making them longer do the o2 sensor wires have to be moved in the connector? oh dumb question where the #$&* is the purge solenoid?
Old Dec 12, 2004 | 08:32 AM
smart monkey's Avatar
Default Re: vtec press.switch? (jess press)
the vtop is near the vtec solenoid on the head of the passenger side of the motor. as for extending wires no need to move wires around. as for the evap if the motor is OBD1 then it is near the Tbody and if it is a OBD2 motor it is on top of the intake manifold
Old Dec 12, 2004 | 03:48 PM
ImportechPerformance's Avatar
Default Re: vtec press.switch? (smart monkey)
If its a geniune b18C meaning JDM TYPE R...I beleive they dont come with a pressure switch...i believe you have to jump the VTEC pressure switch with the Vtec solenoid(at the ecu) in order to trick your ecu...but do a search i know for a fact that it is very well covered here...
Old Dec 12, 2004 | 07:27 PM
jess press's Avatar
Default Re: vtec press.switch? (El RedSkoolingBus)
thanks for the info but my b18c is not a type R its just a jdm. but i cant find a switch anywhere on the engine.
Old Dec 12, 2004 | 09:53 PM
DOHCter's Avatar
its in the same place as every other VTEC solenoid on B series engines... you'll know if its missing, because theres holes in the head right where it goes... just in front of the distributor right by the exhaust cam end cap..
gunnis
Jan 17, 2006 03:36 AM
pouponu
Dec 2, 2005 04:35 PM
Absubtle
Jul 3, 2005 09:48 AM
EKen9
16
Jul 19, 2002 02:43 AM
