For the love of God tell me where the VTEC pressure switch is on a JDM B18C!
Someone please tell me where it is b/c I have no clue. Don't tell me it's on the VTEC solenoid either b/c there is no place to screw it in on a JDM B18C!
Banned
Re: For the love of God tell me where the VTEC pressure switch is on a JDM B18C! (EKen9)
My JDM B18C-R was same way, they have the hole but no switch. It goes in the hole u can see in the pic, kinda under and rearward of the vtec solenoid.
[Modified by blykins, 11:30 PM 7/4/2002]
Re: For the love of God tell me where the VTEC pressure switch is on a JDM B18C! (blykins)
if i remember correctly the jdm b18c motor does not have a vtec pressure switch and as you can see from the pic there is NOTHING there.. why are you looking for it or what is the question for?? vafc install? what?
Re: For the love of God tell me where the VTEC pressure switch is on a JDM B18C! (95CivicEX)
95civicex is correct, on 96 and up motors from japan, there are no vtec oil pressure switch. the ecu gets the signal from the vtec solenoid
Re: For the love of God tell me where the VTEC pressure switch is on a JDM B18C! (DOHCtorTHRUST)
Anyone know how much a USDM solenoid will run?
I've seen them on Ebay for around 40-70 bucks. I just checked and there are none currently available. In general i've heard they are inexpensive...
go to acura/honda and buy a new vtec seloind assembly......
Re: For the love of God tell me where the VTEC pressure switch is on a JDM B18C! (dohcsideSi)
if you are running a obd-1 ecu i would just get it programmed with one wire vtec....makes it real simple and u need no pressure switch...good luck
no need to reprogram the ecu, just ground the wire going to the ecu that goes to the vtec pressure switch. hth
part # 15810-p30-005- $278.28 list. http://www.hondrparts.com
or ask len *points to sig* he may be able to get it cheaper then that.....call him and say you are from honda-tech
Re: For the love of God tell me where the VTEC pressure switch is on a JDM B18C! (infinkc)
you just need the sensor it looks like , i just had to replace mine on jdm motor. from the honda dealer for the b16 jdm it was 50 bucks. Its like a nut screw with the sensor comming out of it. Tell them too look it in the valve timming section, then its the oil pressure switch. I think that is what you need, = p
i might be tired but its the thing on the picture in the middle above the hose near the bottom that is like a 23 mm bolt.
[Modified by kamira, 8:48 AM 7/11/2002]
Re: For the love of God tell me where the VTEC pressure switch is on a JDM B18C! (kamira)
I have JDM B16A2 in my EG civic, but i don't have that switch or a place to hook up that switch. Can some one please tell me why???? so just incase i need that switch i took the Vtec solenoid from my friend B16A3 Delsol which has a Vtec pressure switch, and wire the blue wire to D6 on my P30 JDM ECU. so my question is why my JDM B16A does have a Vtec pressure switch
Hoodwinked
06-30-2018 10:17 AM
jdmstyleEJ6
03-19-2010 10:17 PM
EKen9
07-04-2002 07:18 PM
