Vibration while turning
Old Oct 25, 2010 | 12:39 PM
DRoszyk's Avatar
Default Vibration while turning
I did the whole EK9 H22 swap and everything is running fine and the car is now pretty fast. The only issue that I have is that when I make right turns onto on/off ramps and whatnot at higher speed the car shakes and vibrates violently. Making a left turn its just fine. No vibration at all. I changed out the suspension and the problem still exists. Could it be just that I need an alignment or what? Any help would help a lot.
Old Oct 28, 2010 | 10:10 PM
Ivan's Avatar
senior gold member
Default Re: Vibration while turning
its an axle issue. what axles are you using?
Old Nov 4, 2010 | 03:12 PM
banks358's Avatar
im havin the same issue but the other way around
DRoszyk
Oct 26, 2010 02:42 PM
floored4door
Sep 26, 2008 08:10 AM
oneslowstd
Nov 23, 2006 05:42 PM
matix
Feb 1, 2004 07:15 AM
