Swap wiring question
Old Dec 29, 2002 | 02:03 PM
Soled Out's Avatar
Default Swap wiring question
Im almost to the wiring part of my swap, and i have a quick question.
When i run a wire to the ecu plug (example: running vtec wire from the motor, to the plug on the ecu) how doesthe wire connect into the plug? Im not really familiar with the plugs, is there a pin the wire connects to, or do i have to purchase something to connect it into the plug?
TIA
Old Dec 29, 2002 | 05:44 PM
Soled Out's Avatar
Default Re: Swap wiring question (Gray EG)
Anyone?
Old Dec 29, 2002 | 05:50 PM
leadfoot78's Avatar
I'm at the same point in my swap except its a JDM GSR from hmotorsonline.com and people said you have to bust open the ecu plug and salvage the pins from there that are not being used like AC and use them for what you need like vtec. be careful not to brake the plugs. search and you will find pictures on how to do it i found them yesturday but don't have the link sorry
Old Dec 30, 2002 | 12:14 AM
SoSlo's Avatar
hasport.com has a good wiring section take a look
iliv2xlr8
Mar 4, 2009 06:16 PM
crexsi
Jul 23, 2008 02:27 PM
shbrown
Aug 11, 2005 04:51 PM
JDcompman
Aug 1, 2004 06:31 PM
