swap or supercharge???...that is the question!
Old May 22, 2001 | 02:38 PM
gearhead313's Avatar
25 Year Member
Default swap or supercharge???...that is the question!
here's the deal...
93 delsol si, bone stock...needs to go faster!! What do you guys thing would be a better route?...
B16A or Supercharge the D16Z6?? That is the question! It is lookin like either one would be the same $$$ wise, i just want another opinion
Thanks a bunch for all of your help!
Old May 22, 2001 | 03:05 PM
raene's Avatar
Default Re: swap or supercharge???...that is the question! (gearhead313)
I always thought about it this way....
Every mod you do to an engine removes some potential. You supercharge an engine, that removes a LOT of potential.
However, you put in a NEW engine that makes lots more power, you have lots MORE potential!
This line of thought is making me consider a B18C1 swap in the next year or so...
Old May 23, 2001 | 05:32 AM
LATERALUS's Avatar
New User
i say swap it, and then.....you can go s/c later on. but dump the SOHC
Old May 23, 2001 | 10:06 AM
advanracing62's Avatar
Default SWAP
well let's see there is a dohc vtec del slo here in my town, he runs 15.7-15.8 with i/h/e and a phantom grip, might be runnin slicks too... now if you put a s/c on a 1.6 that runs 17-15??? depending on mods then where would you be??? maybe 14 at the lowest??? buy a b16 build it and then swap. gut out your slo and get the weight down and you'll be quick.. that's if you plan on staying n/a if you want to s/c later then just lightly build the motor and then boost it. you'll be doing good.. If you don't have the cash to build then swap expect to run in the 15, well depending on altitiude.
Old May 26, 2001 | 11:18 AM
ATYPR's Avatar
Default Re: SWAP (advanracing62)
Swap it. Don't go with a b16. GO BIG!! B18C or bigger. If your Sol was a S, the b16a would be OK. With a Si you need more motor.
Old May 26, 2001 | 11:40 AM
dragonsmp's Avatar
New User
I just swapped a B18c into my coupe. I orginally had a 1.6 sohc w/ turbo...I ran 13.9 with it (not bad, just not enough). However, I had almost everything done to it, not much potential! Remember ***Speed*** is addicting. Once you go fast you will always want to go faster.
Old May 27, 2001 | 03:21 PM
25 Year Member
Default Re: swap or supercharge???...that is the question! (dragonsmp)
what do u run now with the B18C???
Old May 27, 2001 | 04:51 PM
dragonsmp's Avatar
New User
We just got it in 2 days ago...It is still missing the tranny motor mount (had to order from acura) and the ecu is throwing a 23 code (knock sensor). We apparently wirred it wrong. I prolly won't even run the car untill I get the Drag Gen 3 w/ Ball Bearing upgrade put on. Then I better be in the high 12's or I will be pissed. We'll see...I'll keep u posted!
Andron
Jun 7, 2014 08:36 PM
JDyzzle
Feb 14, 2011 02:12 PM
hutch311
Sep 23, 2005 01:08 PM
carcraft
Apr 19, 2005 05:34 PM
Awar318
Mar 21, 2004 07:02 PM
