which swap should i go with K,or B series on 98ex
Old 09-15-2005, 04:21 PM
01_S2k_Driver's Avatar
Default which swap should i go with K,or B series on 98ex
what would be the the best swap for my 1998 civic ex
i was also thinking about the rsx-s k20 swap complete swap ecu axles trans. motor mounts for $7,200
from the b series what engine would be best for ek me respond with any ideas or concerns
thanks
planing on boosting after the swap will see if it's the b or the Kseries .....
94-96 (GSR) B18C Engine
Swap: $3085.00
-Only long blocks in stock currently $1850.00 & Completes w/ LSD $3300.00
• 1800cc (1.8L) DOHC Vtec engine.
• 180hp/126trq, 10.6 compression ratio. (U.S. version has 170hp and 10.1 cr.)
• Hydro tranny type.
• P72 OBD-1 or OBD-2 ECU equipped.
• Inquire within for LSD equipped trans. (not all trans are LSD equipped).
• U.S. version of this engine is available. Also, specify which year type you need (OBD-1/2).
97-00 (GSR) B18C Engine
Swap: $3600.00
-Out of stock
• 1800cc (1.8L)DOHC Vtec engine.
• 180hp / 126trq / 10.6 compression ratio. (U.S. version has 170hp and 10.1 cr.) • Hydro tranny type.
• U.S. version of this engine is available.. Also, specify which year type you need (OBD-1/2).
94-98 Integra Type- R Engine
Swap: $4800.00
-Out of stock
• 200hp / 18.5Nm trq / 11.1 cr., DOHC Vtec (U.S. version is 195hp/10.6 cr.)
• Integra-R P73 OBD-2 ECU type.
• We have access to U.S. version Integra Type-R engine's as well.
Old 09-15-2005, 06:31 PM
SixguN's Avatar
Default Re: which swap should i go with K,or B series on 98ex (SOHC1.6LV-TEC)
If this is your first real swap, I wouldn't go with a k right away. And if you plan on boosting, I would go with a ls swap, then turbo it down the road. But if you want a GSR swap, Get it from hmotorsonline. HMO can't be beat.
http://www.hmotorsonline.com/s...30008
Old 09-15-2005, 07:45 PM
HBK GABE's Avatar
Default Re: which swap should i go with K,or B series on 98ex (Sixgundone)
gsr w/ boost
Old 09-15-2005, 08:11 PM
IGotNoSwap's Avatar
Default Re: which swap should i go with K,or B series on 98ex (626CivicSi)
all motor b18c.
Old 09-16-2005, 04:03 PM
drowzysleeper's Avatar
Default Re: which swap should i go with K,or B series on 98ex (IGotNoSwap)
i got a 98 ex too, im going to got with a b18a1 and boost it but i couldnt fint swap mounts do es anyone know where we could get them or if we even need them thanks.
MrHonda10
11-03-2018 12:47 AM
Aleksandarmkd
07-27-2017 12:19 AM
EKtheory
34
10-08-2010 12:36 PM
Nicscivic
12-29-2008 12:21 AM
mucter
Northwest (Sales)
03-17-2006 03:31 PM
Quick Reply: which swap should i go with K,or B series on 98ex
