swap question
Old Jan 5, 2003 | 09:00 PM
GReddy SI's Avatar
Default swap question
i got b16a2, and i want to swap to a 92 vx , ok i want to keep obd2
because i want to leave it like it was in my 2k SI ,
but some one is telling me that I need a 92-95 ex harness
and a p28 or p30 ecu is this true?
because i thought i could just keep my 2k civic si ecu and use the same
harness. someone plz enlighten me
Old Jan 5, 2003 | 10:09 PM
youngkow's Avatar
Default Re: swap question (GReddy SI)
The OBD1 and OBD2 plugs are different, so you will not be able to plug and play. I'm assuming you got the swap from a 2k SI that you had. You should probably use the SI harness, but I'm not sure how the interior harness would plug up. Either way, you will have to do some rewiring. Sorry if that didn't help.
Old Jan 5, 2003 | 10:47 PM
GReddy SI's Avatar
Default Re: swap question (youngkow)
so i could use my 2k harness and ecu obd2 , just that i would have to rewirer the interior harness only then ?
Old Jan 7, 2003 | 03:00 PM
roc109's Avatar
i'm doing the same swap in my 95 cx, i'm going with my old cx harness on the b16a2 motor. i will probably use an obd 1 dist. don't like cutting and joinning wires. if you an xacto knife you can shave your old obd1 injector clips to fit si injectors.it takes a little time
Old Jan 7, 2003 | 06:34 PM
jas0n's Avatar
Please don't hurt me!
why do wanna keep ob2 for more check lights and o2 sensors
id go p28 chipped with a ex harness
Old Jan 7, 2003 | 09:39 PM
GReddy SI's Avatar
Default Re: swap question (couter)
well i decided to go obd1
so i am going to get me a 96-01 gsr or 97-01 typeR harness
that way i can use my b16a2 dist. and get my p07 chipped
would that work
and yes the p07 can be chipped
Old Jan 8, 2003 | 08:08 AM
spektrum's Avatar
Chipping your P07 will work, but I'd reccommend a stock P30 or a chipped P28.
b18csedan
Apr 26, 2010 02:54 PM
itzyaboyzeem03
Dec 5, 2008 12:37 PM
truevietluv636
42
Jul 18, 2007 06:38 PM
killerB16A
Jan 16, 2007 11:01 AM
GReddy SI
13
Jan 6, 2003 04:15 PM
