Swap Problems
Old May 30, 2003 | 01:37 PM
Sinner's Avatar
Default Swap Problems
I'm having problems with my swap.
1. I dont have any clutch. I think I hooked it up correctly.
2. I'm have a coolant leak that looks like its comming from the crankshaft area? I dont know whats going on with that.
3. It always cranks but then never really turns over it just will go pop, pop, and die
Please help me if you know whats going on?
Nick
Old May 30, 2003 | 06:37 PM
Sinner's Avatar
bump
Old May 30, 2003 | 07:46 PM
Turbogixxer's Avatar
Default Re: Swap Problems (Sinner)
what your set-up? ok, without knowing that i try to help you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">1. I dont have any clutch. I think I hooked it up correctly.</TD></TR></TABLE>
try and bleed your clutch slave cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">2. I'm have a coolant leak that looks like its comming from the crankshaft area? I dont know whats going on with that.</TD></TR></TABLE>
That maybe your water pump that is leaking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner &raquo;</TD></TR><TR><TD CLASS="quote">3. It always cranks but then never really turns over it just will go pop, pop, and die</TD></TR></TABLE>
I think that your timing is off, check the firing order and cam timing.
I hope that helps you!
Old May 30, 2003 | 08:16 PM
Sinner's Avatar
does anyone else concur ?
Old May 30, 2003 | 08:32 PM
Default Re: (Sinner)
you said that changed the timming belt? i would make sure that everything is TDC
EDIT: this is his engine: (11:58 PM 5/30/2003) Sinner: I have a d16y8.
Old May 31, 2003 | 10:56 AM
Sinner's Avatar
correct I think its all comming down to somethings screwed up with the timing belt
the ludee
Apr 23, 2008 06:00 PM
spyderpaint88
Mar 15, 2008 09:10 PM
jonnytuner
Mar 4, 2006 04:06 PM
nastydc
Aug 16, 2005 05:59 PM
Airmax55555
Dec 29, 2003 01:35 AM
