Shiftlinkage
Was wondering about the difference between the d series and b series shift linkage. Does anyone know which is longer or shorter I know I can buy a new one but money is tight and I need to cut some were. I have two linkages and possible use two to make one.
Modified by 95civicB16 at 12:05 PM 4/26/2007
Yea i know when i bought the car i was thinking it was a 94 integra. And it turns out to be a 91
. I heard the b series would be shorter since the trany is wider but the pins are not the same angle
. I am having all sorts of problems with this swap since none of the stuff will swap over
. Some day it will run and i hope better then before...
If you cant find a linkage, you can give Steve a call at Hmotorsonline.com. He should have plenty lying around if you're in a jam.
You can use a shift linkage from any B-series civic 92-00 and any integra 94-01. You just cant use the del sol linkage, it's got a bend in it unique to the del sols.
96hatchBoy
Jun 3, 2013 08:43 AM
JDM_EK4_Coupe
Apr 15, 2007 07:50 PM
