Shift linkages??
Old Aug 12, 2009 | 11:29 PM
ramonjones16's Avatar
Default Shift linkages??
WHich linkages fit a gsr tranny????
Old Aug 12, 2009 | 11:33 PM
Default Re: Shift linkages??
and will a b series linkage from a crx fit a gsr tranny?
Old Aug 13, 2009 | 12:04 AM
Ruben19's Avatar
any b series linkage will get the job done
Old Aug 13, 2009 | 12:11 AM
JHang's Avatar
All b series shift linkages are the same except for the del sol
Old Aug 13, 2009 | 12:15 AM
so the crx one will work too
Old Aug 13, 2009 | 12:24 AM
JHang's Avatar
b or d??
Old Aug 13, 2009 | 03:27 AM
jhammond_82's Avatar
Reject Papi
not sure if ALL shift linkage is the same. when you put da linkage in an ef, you need to cut it so it fits right. that tells me that not all of them are the same especially since they make a swap linkage for that specific chassis. yeah, that del sol linkage has a funky bend in it, lol. and, not all d series linkage is the same either.
Old Aug 13, 2009 | 05:36 AM
B....but I found a 94 LS shift linkage so that should work since the 94-01 Integras and the 92-95 civics have the same chassis correct? Does it matter that it came from a cable tranny?
Old Aug 13, 2009 | 05:39 AM
civicgsr's Avatar
Yes
Old Aug 13, 2009 | 10:44 PM
JHang's Avatar
My bad I meant to say 94-01 integras and 92-00 civics linkages the same
widewhite
Aug 28, 2015 05:14 AM
gsxrallday
Dec 22, 2007 02:55 PM
bigislandc2
Oct 11, 2007 10:22 PM
nicko360
May 9, 2007 04:36 PM
93civic_b18b1
Aug 27, 2001 02:09 PM
