Quick Questions #1: GSR to ITR, Engine Conversion.
Old Sep 2, 2003 | 12:27 AM
IntegR97's Avatar
Default Quick Questions #1: 95' GSR to ITR, Engine Conversion.
Asking about Engine Swaps...
What following parts, other than stock (GSR) will I need to convert a GSR ITR?
Old Sep 2, 2003 | 08:49 AM
skribblah's Avatar
Default Re: Quick Questions #1: 95' GSR to ITR, Engine Conversion. (IntegR97)
differant tranny
lsd
lighter flywheel
coated pistons
lighter rods
stronger valvesprings
agressave cams
light intake valves
if your using your gsr head, skunk2 IM, or switch to b16 head & type R IM
higer compression pistons
bigger TB
all i can think of right now.
Old Sep 2, 2003 | 05:26 PM
R6Boy69's Avatar
Default Re: Quick Questions #1: 95' GSR to ITR, Engine Conversion. (skribblah)
have fun with this one... oil squirters
Old Sep 6, 2003 | 08:05 AM
IntegR97's Avatar
i was really asking about like motor mounts and any other items that need to be changed. The motor will be a t B18C5. And does the type-r use ABS also?
Old Sep 6, 2003 | 09:17 PM
super laubo's Avatar
nope, same stuff... the type R's came equipped with ABS brakes also.. there's no difference.. good luck
Old Sep 6, 2003 | 09:22 PM
b17gsr's Avatar
Use the ITR ECU for best results.
** edit: if going in a OBD1 GSR, chip a P28 ECU. **
Old Sep 7, 2003 | 02:58 AM
owen_the_soyboy's Avatar
Default Re: Quick Questions #1: 95' GSR to ITR, Engine Conversion. (crXBoy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crXBoy69 &raquo;</TD></TR><TR><TD CLASS="quote">have fun with this one... oil squirters</TD></TR></TABLE> gsr and itr both have oil squirters.
CAMS are different too.
jdm itr shift linkage is different.
header.
lost motion assemblies.
JayMo05
Oct 30, 2012 10:27 AM
Ivanek00
Mar 3, 2009 08:25 AM
Preludes'R'Us
Jan 20, 2005 11:36 AM
HarryB
May 21, 2002 09:16 PM
ITRmike98
May 20, 2002 05:05 PM
