Question on D16 Swap?!?!
I did a Search But Couldn't find anything. I'm new to this Hybrid stuff cause i drive a accord v6 so I dont know alot about Civic if you guys can help me out I would really appricated, Please dont Flame , but I just recently bought a 92 civic hatchback CX and my friend donated his 99 D16Y EX complete swap to me, I want to know if i can put this swap into my Hatchback cause i heard that the 99 engine was OBD2 and my car is OBD 1 so will this swap go into the hatchback easy or would there be alot of modification needed and what part do I need? I dont want to throw the 99 engine away cause I got it for Free. so any help would do...
i'm in the same boat now is there anything else that is needed.
note: i got the motor out of a 96 civic w/ motor,tranny,ecu,axles,shift linkage,etc. is there anything else that i will need?
You'll need to change the driver's side motor bracket and mount to your stock CX bracket and mount, then it will bolt right in. Pick up a 92-95 EX/Si P28 ECU, add the wiring for the VTEC solenoid, Pressure switch and convert to a 4 wire O2, then drive and enjoy.
system96
Feb 9, 2006 07:28 PM
