Question about engine swap!!!
Old Jul 13, 2001 | 05:18 PM
heinvenkin's Avatar
New User
Default Question about engine swap!!!
I have a 98 civic ex coupe and want to do a b16 swap, but i have a few questions.
has anyone done this swap? if so, what problems or useful information can you offer.
if you get the wiring harness for the new engine, can't you just run the new harness into the kickpanel where the new ecu will be located?
Thank you,
Heinvenkin
Old Jul 14, 2001 | 09:53 AM
Blown90hatcH's Avatar
Default Re: Question about engine swap!!! (heinvenkin)
Get the OBD1 engine...B16 second gen motor, hydro tranns, axles, some minor mounts, use the stock harness from the car, and get the OBD1 ecu. Then get a OBD2-OBD1 conversion harness. If you need one, I can get it. If you can find a 99-00 Si motor, then I would get that. Get the complete swap and all you need is some minor mounts, and some basic wiring. Also, as for the harness into the kickpanel goes.....you cant do that. The harness is also connected to the dash and all that other crap. Use the stock harness and make it work.
HTH-Jason
[Modified by Blown90hatcH, 10:54 AM 7/14/2001]
rustanghunter
Mar 26, 2010 07:58 PM
MurtazaDSM
Nov 3, 2009 03:48 PM
cholo900rr
May 14, 2009 05:26 AM
heunde
10
Apr 10, 2008 12:32 AM
be8teensee1
Dec 9, 2006 09:37 PM
