obd2b civic want obd2a swap
I habe 1 problem....my civic is obd2b.But now i bought a swap b16a2 whit obd2a ecu and bouth harness cabel....
can i leave the inrerrior cabel and go ahead 2 the ek4(b16a2) ecu,and that whit the cabel 2 the engine.
i hope you understand what i mean
sry for my bad english
greetz from germany
greetz from germany
Re: obd2b civic want obd2a swap (heunde)
Okay im not quite understanding but i think i know what your asking. Answering the best i can.
You bought a B16A2(OBD2B) with a OBD2A ECU. All you have to do is use your existing harness and get a conversion harness from OBD2B->OBD2A, but that ecu your using is not good. Get you the ECU for your motor (P2T) and dont have to buy a conversion harness or get a chiped P28 and conversion harness from OBD2B->OBD1.
footwork mastery
so you're saying you want to use the wiring harness that came with the b16 swap? if that is what you're saying it'd be a lot easier to just use your current harness because using that obd2a engine harness in an obd2b car will not work. i hope i understood what you were asking?
i have a question that i really need help on...
i have a 1999 civic ex and i am planning to swap in a 2000 ls motor soon. my question is, would a 2000 ls ecu run in my car because i heard there was some kind of security key mobilizer that disables my car from starting with the 2000 ls ecu??? is that true?? do i have to use some sort of jumper harness?
please help me out guys!
