a question???
Old Nov 9, 2007 | 05:48 PM
cadwiese's Avatar
Default a question???
i have a 93 si hatch (usdm) and a 96 b18b1 (jdm) and the upper drivers side mount does not line up right does anyone have a info for me? ohh also i had a b18b1 (usdm) in there before this engine so i figured that it would would be an drop in job
Thank You,
Justin
Old Nov 10, 2007 | 08:04 AM
cadwiese's Avatar
Default Re: a question??? (cadwiese)
anyone?
Old Nov 10, 2007 | 08:17 AM
HeikDiesel's Avatar
i think your a little confused on your engine codes. I dont think there is a JDM b18b1
Old Nov 16, 2007 | 09:02 PM
jdmcars.com's Avatar
Well, regardless if you are mixing up some codes, there are 2 types of drivers side mounts for the Bseries.....there are 2 bolt or 3 bolts styles (how mount bolts/nuts required to bolt the mount to the side bracket).
Get the proper combination of both (or buy the right ones if you don't have the proper combination with everything you have already, which you should) and put it together.
We do offer mounts that work, but still need to know what you have.
Maybe you should put up a picture of what you are working with and what is not lining up for you.
Old Nov 17, 2007 | 02:57 PM
cadwiese's Avatar
i got the munt thing fixed i just put on the 3 bolt pattern one i had instead of the 2 bolt pattern one it came with
tamadrumr88
Mar 21, 2016 10:46 AM
TurboLaxx
19
Feb 20, 2006 11:37 PM
CRXified
10
Apr 14, 2005 08:12 AM
