problems with speedometer.
Old Feb 10, 2006 | 03:28 PM
vtec fan's Avatar
Default problems with speedometer.
Hey guys,my friend has a 98civic with B16 inside, using a 2000 si cluster every thing else works exept when he got the car the speedometer did not work I checked the VSS voltage, getting voltage in the 0 to 5 volt range, installed a acluster from a 96 A/T civic when I turned on the car the speedometer went to 20mph and just stayed there whether driving or not, I switched the circuit board at the back of the Si speedomiter, with the one on the 96 civic A/T and no change, any suggestions I do not know what else to try. Thanks for your help.
Old Feb 11, 2006 | 05:18 PM
www.megameet.org's Avatar
Default Re: problems with speedometer. (vtec fan)
replace the whole speedometer. The needle may have been taken off and put back on? If the vss is fine, thats the only thing I could think off is the speedo itself.
They are only like $80 at honda.
phrenzy
Apr 25, 2016 10:05 AM
jaconlon1
Mar 5, 2012 10:42 AM
SirEm1
May 18, 2007 07:33 PM
