Piston-to-Valve clearance question for G23 build
Old 12-08-2013, 04:21 PM
91_da9's Avatar
Default Piston-to-Valve clearance question for G23 build
I'm getting a good deal on a worked h22a head off my buddy. It's shaved .020" and is running type s cams with flat faced valves. Does anyone know if I'd have PTV clearance issues with k20a2 pistons In the F23 block? Has anyone shaved their head this much on this build, or does anyone have any suggestions on pistons I can run and still be okay? Not sure how accurate the zealautowerks calculator is but it's saying I'm going to have a -.020" piston to deck height, which wouldn't that mean I'm most likely going to smack valves or do I not understand that right? Can someone help me out lol so I don't ruin a head with over 2k into it lol
Old 12-08-2013, 04:31 PM
10psiLsEf2's Avatar
Default Re: Piston-to-Valve clearance question for G23 build
Why dont you have the motor clayed?
Old 12-09-2013, 02:04 PM
hondamark35's Avatar
right. or do it yourself.
91_da9, there are too many unknowns, too many variables to have this answered on here. this is a perfect example of when an engine should be "clayed" for clearances. Even if I were to tell you "yes, in fact it will be fine," I won't be responsible for replacing a blown engine if it fails. You will. Measure it yourself to know it's right. Or, pay a professional who can give you a guarantee.
monster_c
11-26-2011 12:23 AM
SilverEk3dr
04-30-2009 07:53 AM
HaTa
09-09-2007 08:45 AM
ludesleep
07-24-2006 07:34 PM
sleepyhamsterlx
12-25-2003 09:47 AM
Quick Reply: Piston-to-Valve clearance question for G23 build
