P28 question ?
Old Aug 25, 2002 | 09:34 AM
jack25racing's Avatar
Default P28 question ?
Do you know if P28 ecu (stock) check for KS, VTS or something else an integra 98 nonvtec don't have. I don't have vts on my jdm b16a head and I don't have plug ks. I presently control the vtec with vafc and use my p75 in my lsvtec, is run great but you know why I want p28.
I ask this because I build my own obdII-obdI harness and I don't already received my chip for the p28 (skunk2) so I had try my p28, but the check engine light was ON.
It's probably because the ecu check for some missing sensor but I am not sure of this, I will try to read the code when I will finish my weekend shif, but before I will appreciate if you can help me to understand that.
Thanks !!
Old Aug 26, 2002 | 04:10 AM
Default Re: P28 question ? (jack25racing)
up
Old Aug 26, 2002 | 09:57 AM
X2BOARD's Avatar
Crank angle sensor on that bottom end ?
Old Aug 26, 2002 | 11:26 AM
eg6ajk's Avatar
is the motor JDM b16a OBDII (96+) if so the code most likly due to lack of oil pressure switch on the vtec housing
its a green two wire sensor, it is not found on 96+ JDM motors, your other alternative is to go with a USDM specs or OBDI JDM vtec housing
Old Aug 26, 2002 | 11:40 AM
Default Re: P28 question ? (eg6ajk)
The head is an b16a head first generation so I don't have vtec pressure swith.
Do you think power chip like skunk2, JUN.. check for sensor I don't already have ?
Thanks !!
Old Aug 28, 2002 | 01:20 AM
tttttttt
Sycokid666
Feb 14, 2017 05:10 PM
mcgee*
11
Apr 2, 2006 07:38 PM
Boosted_93_Si
Oct 11, 2005 10:01 AM
crete10
Mar 27, 2003 01:19 PM
