Overheating issues
Old Feb 27, 2003 | 05:51 PM
Sohc Driver's Avatar
Default Overheating issues
I recently got my engine swap done and trying to enjoy it..but im running into problems. My heater didn't work so i took it in to have a shop look at it. He told me he wasn't able to exactly identify the problem, so he asked me to take it in this next monday so that he can check it out completely. When he pulled the hoses coolant flowed out of the engine. But i refilled the resevoir and the radiator. So i left and drove not more than 6-8 miles down the road and i notice the temperature guage approaching the "H" So i pulled over right away on the highway. I had a friend come up and we checked the resevoir, it was still full, but the radiator was bone dry. He told me that it maybe because the engine was dry because when we unplugged the hoses the coolant ran out. So that when we refilled the radiator and resevoir it wasn't enough coolan. So we filled up the whole engine again with coolant. Temp was back to normal...driving for about 20 more miles the gauge starts approaching the "H" again but not as high as before just a lil more than halfway between "H" and "C"...I check the resevoir..still full..but the radiator was not full...but not completely empty either. I checked the heater hose in the back of the engine and there is a leak...small drips but constant. My question is...is everything ok? do i just need to replace that hose and tighten it? I hope i didn't blow my engine or anything. Oh yeah..its really cold outside too in the high 30s.
Any opinions and ideas on why my car is overheating? Or is that small leak the culprit?
Khoi
Old Feb 27, 2003 | 08:28 PM
Default Re: Overheating issues (Sohc Driver)
Well..problem fixed i hope....that one hose that was connected to the rear of the engine had a clamp on it that was too big. So we replaced it with a smaller one. This solved the leak. I drove it for 20 miles...no increase in temperature according to the temp gauge in the cluster. I also checked the coolant resevoir and its still at max. I held both radiator hoses...the top and bottom both hot...I checked for leaks no leaks..is the problem fixed?
Khoi
Old Feb 27, 2003 | 11:41 PM
drift's Avatar
New User
the easiest way for me to refill the engine full of coolant without trapping any air bubbles is to fill the radiator til it's almost topped off. loosen the crack valve near the thermostat and bleed any air bubbles.
i'll start the car with the cap off and let it warm up til i see coolant flowing in the radiator, letting me know the thermostat is open and the system is circulating.
i'll then add coolant until the radiator is topped off, turn off the motor, install the cap, fill the reservoir. i'll then run the car some more to circulate the system some more and check it when it's cold to ensure the radiator is still topped off.
also, be sure you do all this with your temp selector lever on your climate control panel in the "hot" position, as that lever controls a valve that diverts some of the coolant to enter the heater core to heat the incoming air into the passenger cabin. this will ensure any trapped air in the heater core is circulated out while you refill the system.
Old Feb 28, 2003 | 07:01 AM
Default Re: Overheating issues (drift)
the wierd thing is...the heater didnt' work before..and now it does...why is that?
Khoi
Old Feb 28, 2003 | 08:41 AM
Hey guys..i just checked my resevoir..i havnent' driven it since last night..and checked on it this mornign..and my resevior is empty...whats goign on?
Khoi
and i checked that one hose that was leaking before...its leaking again! what the hell...
[Modified by Sohc Driver, 11:48 AM 2/28/2003]
Old Feb 28, 2003 | 06:28 PM
All_Lag's Avatar
Well first off id replace the hoses, then id just check to make sure the radiator core and/or reservior bottle arnt leaking themselves. It could also be your Engines Drain or Water jacket core plugs leaking.
I know this would ntcause your reservior to drain but make sure your Radiator cap is maintaining proper Pressure it could be part of the problem.
[Modified by SlowSOHC, 3:30 AM 3/1/2003]
Old Mar 1, 2003 | 10:01 AM
Default Re: Overheating issues (SlowSOHC)
Well...i bought a new heater hose...turns out the old one was too short and it didn't clear the bead where the hose hooks up.. So i bought a new hose and new clamps. Seemed to solved the problem..no more over heating..but i notice my resevoir is fluctuating. When i left it over night..it lowered just a lil bit under max when i checked it in the morning, but when i drove it to work and then checked it out again..it went a lil over max...what is going on..still no over heating, radiator is also full and the thermostat is in working order..any ideas?
Khoi
[Modified by Sohc Driver, 1:04 PM 3/1/2003]
Old Mar 1, 2003 | 01:01 PM
any ideas?? bump
Khoi
iHEARTMYCiViC
Jan 19, 2010 04:53 PM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
Katsuhiro_KANeda
Aug 2, 2003 06:14 AM
Sohc Driver
Mar 3, 2003 08:17 AM
