opinions on budget setup
Old May 9, 2002 | 09:30 AM
KRiS1's Avatar
Default opinions on budget setup
I have a tight budget and would like to get a swap for my 94 Si. I got qouted a good price on a 2000 B20Z block with a 95 LS head milled to provide 10.0.1 compression, 95 LS ECU. and a GSR tranny with new ITR clutch & flywheel. I'd also keep the AC and PS as well as get I/H/E a fuel pressure regulator and have it dyno tuned. Would this make a good daily driver? What kind of power and ETs would this setup yeild?
[Modified by POS Hatchback, 10:44 AM 5/9/2002]
Old May 9, 2002 | 09:56 AM
hybridreams's Avatar
Default Re: opinions on budget setup (POS Hatchback)
turbo or n/a?
Old May 9, 2002 | 09:57 AM
KRiS1's Avatar
Default Re: opinions on budget setup (hybridreams)
Id stay N/A
Old May 9, 2002 | 11:12 AM
I'd bump the compression up a little more. stock internals? would make a good dd, yes
Old May 9, 2002 | 11:21 AM
KRiS1's Avatar
how much can I mill the head without running the risk of the valves hitting the tops of the pistons? and what compression will it yield? What would be a good compression? Id rather use pistons to raise the compression rather than mill the head excessivley.
Old May 9, 2002 | 12:28 PM
h22aintegra's Avatar
if you want power get a b18b ls tranny and a gsr head even an older model ls will do if your on a tight budget an ls motor is around 1,200 or so take a look it is well worth it
Old May 9, 2002 | 02:16 PM
BROOD's Avatar
Default Re: opinions on budget setup (h22aintegra)
IMO any CRVtec or LS/Vtec is not really a budget setup. Anyways, I think your plan is a good start. I second upping the compression if you're staying n/a. The GSR trans is a good idea over the LS trans. I'd replace the stock rod bolts with ARP's while you are at it.
Good luck
[Modified by SLPR, 3:17 PM 5/9/2002]
Old May 9, 2002 | 02:24 PM
KRiS1's Avatar
Default Re: opinions on budget setup (SLPR)
At this moment I have no intention on going with a VTEC head, but could I build the bottom end for VTEC duty in case I change my mind and keep the LS or B20 head for the time being? What would I need to do? , toss some higher comp. 84.5 slugs and add VTEC oil and water pumps. Anything else?
Old May 9, 2002 | 07:18 PM
KRiS1's Avatar
up
EF8KiLLaBeE
Jan 21, 2006 10:37 AM
PinkMaggit
Dec 11, 2005 10:56 PM
MugenGSRb18
Sep 7, 2004 12:43 AM
HybriDNA
Nov 7, 2002 01:18 PM
Incognito
Oct 31, 2001 11:51 AM
