OBDII or OBDI convression in B18C5 into EK coupe 96 (d16y8) ???
Old 05-31-2008, 04:55 AM
loverboy's Avatar
Default OBDII or OBDI convression in B18C5 into EK coupe 96 (d16y8) ???
Hello friends !
well im going to do an ITR engine swap into my ek coupe civic 96 (d16y8 engine).
I need your advice in what will be the best OBD situation to go with??
A. I know I can stay OBDII and use the original P72 ECU of engine.
B. Im not shore but I think I can use an OBDI P30 ECU.
What will be the best way 2 go ? what modifications ill need to do in the 2 options ?
Old 06-05-2008, 11:31 PM
loverboy's Avatar
Default Re: OBDII or OBDI convression in B18C5 into EK coupe 96 (d16y8) ??? (loverboy)
Well guys !
I could realy use some help ???!
Old 06-07-2008, 04:38 PM
abelcr's Avatar
change to obd1!!!!
Need the harness obd2 to obd1!!! easy!
Old 06-09-2008, 06:26 AM
loverboy's Avatar
Default Re: (abelcr)
Thanks !!
But which ECU i should be using ?? will it be good enough to the enine without any modifications ?
But which ECU OBDI should i be using (if im going to swap an B18C5/B18C ITR engine) ??
These r my converssion harness options:
1.jdm-in-stock SKUNK2 HARNESS - 128$ (http://cgi.ebay.com/ebaymotors/ws/eB...m=260248823490)
2. raceup harness - 100$ (http://cgi.ebay.com/ebaymotors/ws/eB...m=220242709549)
3. Rywire harness - 95$ (http://rywire.com/store/obd2b-obd1-c...6e410182f6c602)
4. xactdyno harness using custom mold that uses push-to-seat pins -$70(http://cgi.ebay.com/ebaymotors/ws/eB...m=330240859824)
5. streetimports harness using custom mold that uses push-to-seat pins - 50$ (http://cgi.ebay.com/ebaymotors/ws/eB...m=310056751254)
What will u recommend ??
Modified by loverboy at 10:33 AM 6/9/2008
Old 06-10-2008, 09:39 AM
vteg94's Avatar
obd1 with a chiped p28 and then tune it...
Old 06-14-2008, 04:02 PM
mtber's Avatar
You can use a simple obd2a to obd1 harness with a chipped obd1 vtec ecu mapped for your itr motor.
For more information on what this all is, read over http://www.phearable.net/tech/....html
nappyrat
02-09-2007 08:15 PM
Kobal
09-15-2006 05:32 PM
Pooge
07-11-2003 10:04 AM
goat442003
06-21-2003 07:16 PM
hybrid_KJ
01-08-2002 05:28 AM
Quick Reply: OBDII or OBDI convression in B18C5 into EK coupe 96 (d16y8) ???
