Obd2b on an obd2a engine with obd1 ecu
Old Jan 9, 2020 | 05:35 PM
Tithur14's Avatar
Default Obd2b on an obd2a engine with obd1 ecu
What do I need to change beside the dizzy plug? Does everything will fit and work or not?
Old Jan 11, 2020 | 09:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Obd2b on an obd2a engine with obd1 ecu
Your question is incredibly vague. What is the year/model chassis ? Do you have the engine harness from this car or something else ? What ECU do you intend to use ? What year/model distributor do you intend to use ?
Old Jan 12, 2020 | 07:26 AM
Tithur14's Avatar
yes! So I have a '97 b16b jdm obd2a. The harness that I will put on will be an obd2b from a '00 civic si cadm. The ecu will be a chipped obd1, Im not sure what model it is but it was working on an obd2a engine before... For the distributor, I will use an obd2a convert with the good plug for the harness, the blue remaning wire will be for the rpm because the obd2b harness only use 8 pin.
Old Jan 12, 2020 | 10:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Is your car the same as the engine harness... '00Civic Si CADM ?
Old Jan 13, 2020 | 03:29 AM
Tithur14's Avatar
yes!
Old Jan 13, 2020 | 11:22 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Your engine harness distributor plug has 8 wires in it and your OBD-2A distributor will have nine. The one extra wire in the distributor will be the blue RPM/Tach wire. Connect the other eight wires color to color... including the large black/yellow wire in the distributor to the small black/yellow wire in the engine harness distributor plug. Finally, connect the left over blue RPM/Tach wire to the Tach test port wire (blue with silver bands) on the left side of the engine bay near the clutch master cylinder reservoir.
All other wiring should be the same plug styles I believe... although I must admit I am not sure if there are any differences between USDM and CADM engine harnesses... so take this information with an "*".
In the cockpit, you will need to purchase an OBD-2B -> OBD-1 ECU harness adapter to be able to plug in your ECU.
cltnmcqn
Jun 19, 2017 09:06 PM
doch-vtec
Engine Management and Tuning
Jul 1, 2013 07:26 AM
DomkeBoy
Aug 10, 2012 07:58 PM
vlc92189
10
Jan 29, 2010 10:50 AM
apice
Mar 19, 2008 03:35 PM
