obd-2 LS swappers
I used the civic harness when we dropped a '97 LS in my '92 VX but I would use the LS harness caues then you dont have to modify all your plugs. The LS harness should plug right in.
Just get an OBD-1 ls ECU 94/95 p75 from a 92-95 teg (94 or 95 if you want the ECU bolt holes to line up perfectly). All the plugs from the engine will work fine with the plugs on the shock towers. No cutting or splicing needed. Hope this helps.
G
G
