OBD 0 to OBD2b
Old Jul 15, 2006 | 10:21 AM
2doorwhore's Avatar
Default OBD 0 to OBD2b i searched
ok i got a 00 civic si motor blew head and block no good i found a obd 0 b16 cheap what would have to be changed and i am still obd 2b any and all help is needed
Old Jul 15, 2006 | 02:09 PM
Jason-'s Avatar
Sell the motor and buy obd1 or obd2. That'd be easier I think. But.. I hope Poison or Skunk come in here soon.
-Jason
Old Jul 16, 2006 | 12:36 AM
duggy's Avatar
Default Re: OBD 0 to OBD2b i searched (2doorwhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2doorwhore &raquo;</TD></TR><TR><TD CLASS="quote">ok i got a 00 civic si motor blew head and block no good i found a obd 0 b16 cheap what would have to be changed and i am still obd 2b any and all help is needed</TD></TR></TABLE>
ALOT would have to be changed. Water necks, throttle bodies, injectors, altenators, distributors, and a gripload of other stuff would have to be changed out.
Save yourself the time. It might be cheap for the motor, but you still have to buy misc stuff and waste time on that.
Old Jul 16, 2006 | 06:35 AM
2doorwhore's Avatar
what if i just wanted to use the head in my 96 ls to do a ls vtec what would then have to be changed?
Old Jul 16, 2006 | 02:36 PM
Katman's Avatar
if you still have your blown '00 Si engine, you can convert the OBD0 B16 to be compatible with your Si by transferring these parts over:
distributor
alternator
wire harnes
injectors
complete intake manifold w/throttlebody
transmission + flywheel + clutch
exhaust manifold w/both 02 sensors
VTEC solenoid and IAT sensor.
.....all of this will bolt up to the 1st gen B16 engine.
The CKF sensor would be an issue, but there's a wiring trick around this if you read my article here:
http://technet.ff-squad.com/ckftrick.htm
But, if you don't have your Si motor anymore, then yeah its totally not worth trying to make the OBD0 B16 be compatible with your Si. Might as well look for a 92+ B16 engine.
Old Jul 17, 2006 | 02:58 AM
2doorwhore's Avatar
thanks everyone
3Rd GeAr PuLl
Jan 15, 2007 05:59 AM
streetlvlhatch
Feb 18, 2004 02:47 PM
ASHY-ELBOW
Jul 23, 2003 09:12 AM
2000CX
May 21, 2003 07:42 PM
Sassafrass
Mar 18, 2003 05:47 PM
