Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
problems with overheating
Old Mar 18, 2007 | 03:37 PM
DJaeMac's Avatar
Default problems with overheating
my boosted em2 tends to overheat alot. i took out the radiator and had it checked, but no leaks. also, when im boosting coolant starts to burst out. my thermostat is brand new. anyone know what my problem is?
Old Mar 18, 2007 | 05:48 PM
ley's Avatar
ley
maybe an o2 sensor is fried and not telling the fan to turn on.
Old Mar 18, 2007 | 06:17 PM
sujak's Avatar
slim fans ftw
Old Mar 18, 2007 | 06:27 PM
fg2si!kid's Avatar
New User
Default Re: (ley)
the o2 sensor would not tell the ecu to turn the fans on thats the job of the CTS
(coolent temp sensor ) thats if his fans are not working that turbo sits right in front of the engine does it not ? i would make sure the cooling system has all the air out of it and maybe think about puting a heat shield between the turbo and the engine check your coolent level and are you puting the corect mix of water and coolent in ? also is your heater working normal ?
Old Mar 18, 2007 | 08:46 PM
Boilermaker1's Avatar
Is it tuned? You're boiling coolant. Likely issue... headgasket went out the window.
Old Mar 18, 2007 | 10:56 PM
DJaeMac's Avatar
my fan is working fine and so is my heater....
i was told it was the headgasket, but i want to make sure so that i don't go wastin my money again and again...
yes, my car is tuned and was running right for the 1st week then coolant started splashin out
Old Mar 19, 2007 | 05:19 AM
well let it cool, then fire it up and let it idle for a while with the cap off.... see if the coolant drops (air bubbles) then add more).
Old Mar 19, 2007 | 12:00 PM
DJaeMac's Avatar
so does that mean if it boils my headgasket went out?...
because the coolant has been boiling alot lately and i went through 3 gallons of brand new water coolant in the past week
Old Mar 19, 2007 | 02:32 PM
Its likely that it blew. You're getting something really hot in the water in a hurry for it to boil and it not stop... you're basically exceeding the radiators capacity. If you were blowing combustion gasses into the water jacket, that would do it.... blown gasket. Drain the oil out and see if there's water in it. Newly boosted and it wasnt blowing coolant until it was boosted is likely a blown headgasket.
Old Mar 21, 2007 | 12:04 PM
DJaeMac's Avatar
ok. i just found out that my heater isn't functioning properly. At first it blows hot air then slowly turns to cold air. Is it due to water pump failure?....Also if the water pump is failing, will it cause the coolant to boil?...or do i have to change the headgasket also?..
Thanks for everyones help..
Old Mar 21, 2007 | 12:06 PM
ley's Avatar
ley
check to see if your radiator fluid is bubbling, thats a common sign that its the head gasket on any car.
Old Mar 21, 2007 | 12:17 PM
DJaeMac's Avatar
yes, it boils and it shoots out of the reservoir tank and splashes all over my engine
Old Mar 21, 2007 | 01:04 PM
ScubaStevo80's Avatar
Default Re: (DJaeMac)
If its coming out your exhaust as white smoke or going into your oil, then its the headgasket.
If its blowing out your resevoir which you stated above, you have a leak/crack in the system. The coolant system is pressurized and will find its way out of cracks/etc. Check your resevoir for cracks, check the hoses, etc. Also, check to see if your fan is turning on. Coolant would burn me in my non-boosted car that doesn't overheat after its at operating temperature, so that may not be specific to your car.
Old Mar 21, 2007 | 01:38 PM
DJaeMac's Avatar
no cracks on reservoir or radiator or hoses. No white smoke out of exhaust.
yes my fan turns on and is in perfect condition.
i guess ill just have to change the water pump and headgasket to be sure.
Old Mar 27, 2007 | 11:12 AM
iGGY366's Avatar
I had the same problem a few weeks back. It's a blown head gasket. Honda did mine under drivetrain warranty.
Bb16ahatch
Mar 9, 2007 03:40 PM
civicslug
Dec 28, 2006 07:52 AM
yellowturbo
Jan 7, 2004 02:44 PM
spart
Feb 27, 2002 04:07 PM
