need help on a b18b swap in a DA
Old Apr 29, 2004 | 08:19 PM
h22xvietboy83's Avatar
Default need help on a b18b swap in a DA
sup im new here. nice site u guys got going.
okay i already did a search but i didnt find much info on the questions i have.
i have a 93 integra shell. im buying a complete 97 b18b. will the hydro tranny fit into the integra? also with the harness i have now can i just use an obd-1 use to make the swap easier? will everything else fit into my car fine? thanks for the help
Old Apr 29, 2004 | 10:52 PM
Redline130's Avatar
Default Re: need help on a b18b swap in a DA (h22xvietboy83)
Unless you want to convert your car over to use a hydro tranny, I would look for a cable type tranny. It will probably be easier. Use your existing wiring harness and ecu and you should be fine.
Old Apr 29, 2004 | 11:10 PM
Default Re: need help on a b18b swap in a DA (Redline130)
what do i need to convert my car to use a hydro tranny. is it a hard process? the reason why i ask is cause im buying a complete 97 b18 and i dont wanna spend more money to buy something that i dont really need to buy if the hydro works.
Old Apr 30, 2004 | 08:19 AM
VTECVillain's Avatar
You will need to make a custom upper tranny mount and source the hydro lines and clutch cylinder from a 92-95 Civic or 94-01 Integra. It will be some added work for sure. That is unless the HASport EF hydro kit can be adapted to work with the DA chassis.
Old Apr 30, 2004 | 10:23 AM
Default Re: need help on a b18b swap in a DA (VTECVillain)
Thanks a lot
Old Apr 30, 2004 | 10:48 AM
i have another question. the b18b hydro tranny has an act 6 puck clutch would it work with a cable tranny?
Old Apr 30, 2004 | 06:16 PM
Colin's Avatar
if you use the hydro tranny you'll need to pay extra to get it to work in your car
if you sell the hydro tranny you can sell it and buy a cable tranny
-so either way you're gonna be buying more parts....but hopefully the $$ you get from selling the hydro tranny will be able to pay for all of the cost of the cable tranny (you may even have some $$ left over depending on what happens).
which method is actually cheaper? probably buying the cable tranny. IMO thats the best option, I personally like cable trannies and don't think its worth the extra efford to get a hydro tranny into a DA.
Old Apr 30, 2004 | 07:31 PM
Default Re: need help on a b18b swap in a DA (91IntegGS)
i am going with a cable tranny . the hydro tranny has an act clutch in it. would the clutch work for a cable tranny?
RollingSuicide
Transmission & Drivetrain
Jul 22, 2009 05:29 PM
4cylinders-of-fury
Feb 25, 2007 06:46 PM
spyz34
Nov 17, 2004 09:46 AM
Tru Dynamix
Jan 2, 2003 07:22 PM
MR. ARIZONA
Sep 2, 2002 02:17 AM
