Need ek swap help...
Old Jan 7, 2002 | 04:55 PM
hybrid_KJ's Avatar
Default Need ek swap help...
My friend has a 97 dx hatch and we are looking to throw a jdm 94-95 b18c into it. I want to know if I can just plug the 94 engine harness into the 97 car harness, run the vtec, ks, and iab wires to the ecu and be done with it. I know it can work the other way around by plugging a 96+ engine harness into a 92-95 civic I am just curious if it will work the other way around.
Thanks
Kevin
Old Jan 7, 2002 | 05:17 PM
Kamin's Avatar
Default Re: Need ek swap help... (hybrid_KJ)
no your gonna have to convert to obdI i think.
Old Jan 7, 2002 | 05:37 PM
Jackson's Avatar
Default Re: Need ek swap help... (KAMiN)
what are you talking about?
Old Jan 7, 2002 | 09:51 PM
misledyouth's Avatar
New User
Default Re: Need ek swap help... (Jackson)
what i had to do was use my obd2 harness from the car the enige is going into and then you might have to switch some plugs. but the big thing is making an obd2 to obd1 harness converter so u can use the obd1 ecu.
if you have any questions
email
m1sledyouth@hotmail.com
jesse
Old Jan 8, 2002 | 05:28 AM
Trey's Avatar
25 Year Member
Default Re: Need ek swap help... (misledyouth)
Check out http://www.jspectuning.com/6gen/ for all the info you'll need.
As for the wiring, just use the Civic engine harness, swap the plugs listed on the site and get an OBDII to OBDI ecu converter harness to run the OBDI ecu. That will get you running.
Unphzd
18
Aug 24, 2010 07:25 PM
B18CUL8R
Dec 23, 2008 09:58 AM
advan414
Feb 13, 2008 11:51 AM
deluzracerx
Jun 18, 2005 07:51 AM
Type RS
Nov 16, 2002 01:28 PM
