My Idle Problems Still Exist
Old Feb 18, 2004 | 12:14 PM
eak_degenr8's Avatar
Default My Idle Problems Still Exist
Hello everyone...this is my first post on honda-tech. Here is my problem. I have 94 B18C1 with a Skunk 2 single butterfly IM, 98 P73 ECU, in 96 EK hatch...I have had a high idling problem for a long time & since it has been cold it dies after a second or 2 of running. I checked & re checked for vac. leaks and there are none. IAC was replaced in the summer & ECU was repined. There were no CEL codes at that time. I just replaced the Throttle Body last week from another GSR with no FIT Valve and now it is idling super low at 500 rpm & lower & it dies quicker than before. I adjusted the idle screw almost all the way out & it had no efect at all. It is now throwing a code (I will check when I get home) I think with the TPS. Is there any way to adjust the FIT (Fast Idle Thermo) Valve to get it almost closed up on my old throttle body. I also scraped the terminals clean on dist. Would a blown head gasket be another cause of this on going idle problem? I am at my wits end with this damned project.
Old Feb 18, 2004 | 12:23 PM
civicsib16b's Avatar
Default Re: My Idle Problems Still Exist (eak_degenr8)
u might need to replace your iac (idle air control) sensor that might be your problem.
michaelsej1
18
Feb 21, 2011 07:13 AM
tothewall
Oct 7, 2010 12:43 PM
dth0ng69
25
May 18, 2009 08:30 AM
Midori Green
Jan 3, 2007 03:13 PM
madcrossover
Jul 2, 2005 10:18 AM
