My H22A Civic Coupe Suspension Problem (HELP!?!?)
Old 01-12-2003, 10:09 AM
ErikDaGenErik's Avatar
Default My H22A Civic Coupe Suspension Problem (HELP!?!?)
Lately I have been hearing rapid "thuds" coming from my suspension somewhere when I give it more and more throttle in 2nd and 3rd. I didn't know if its my axles, tires, or anything else in my suspension.
I have finally figured out when when I get that noise. Everytime my car dips down from a lump/bump, or when my nose plunges down when I accelerate, the "thud"s start up again.
Is it normal for 2gen Integra axles start acting up when the car is lower with an H22A? Or are my axles messed up? I'm pretty sure its not wheel hop because I had my friends stand outside while I drive my car in second passed them; they saw no tires spinning.
Any help at all is appreciated.
Old 01-12-2003, 02:32 PM
fastwanabe's Avatar
Default Re: My H22A Civic Coupe Suspension Problem (ErikDaGenErik)
THUD huh? I'd check the rear mount.
Old 01-12-2003, 03:38 PM
poison's Avatar
you'll have to be more specific on the 'thud' and where exactly it's coming from...
sounds to me like you either have bad struts, the front lca and uca is not tight enough (maybe became loose after doing the swap), or the strut hydaulic stem is not tight on the strut tower.......
my recommendation would be to check all bolts around your suspension.
Old 01-13-2003, 01:59 AM
Default Re: My H22A Civic Coupe Suspension Problem (poison)
whats lca and uca?
Old 01-13-2003, 03:04 AM
xpurespeedx's Avatar
whats lca and uca?
lower control arm, upper control arm
Old 01-13-2003, 08:04 AM
Specail Ed's Avatar
Default Re: My H22A Civic Coupe Suspension Problem (xpurespeedx)
What mounts are you running? We've done two H22 swaps with HASport mounts and both make a weird rumbling noise when the suspension is compressed. I think what the problem is are the axels. My car is only doing it on the passengers side. Try switching the Integra inner joint with a Prelude inner joint on the axel on that side. I've heard that works.
Old 01-13-2003, 11:58 AM
H22EK's Avatar
Default Re: My H22A Civic Coupe Suspension Problem (Specail Ed)
the rumbling noise that you are hearing are the axles binding. what axles combo aRE YOU running?
Old 01-13-2003, 12:13 PM
Default Re: My H22A Civic Coupe Suspension Problem (H22EK)
i had a feeling they were the axles. for one thing, one of the cv boots is ripped and grease is just everywhere. Im using Hasport btw.
i'm using stock '90-'93 integra LS axles.
WHat axles combination should i use?
I was thinking about going to kragen/monument parts/pep boys (lifetime warrenty) and getting '92-'93 GSR axles since they are designed to hold more HP than the LS. is that an ok idea?
[Modified by ErikDaGenErik, 9:14 PM 1/13/2003]
Old 01-13-2003, 01:38 PM
jacobyb's Avatar
Check your hood. I know it sounds funny, but the '92-95 Civic's have some hood clearance problems with the H22. If it is close enough, when you floor it and you are in the meat of the power, it will flex upward enough to hit the hood. This has been a problem with several people that I know with the same swap you have.
Old 01-13-2003, 11:50 PM
H22EK's Avatar
you are on the right track to being cost efective, or if you have the $ get some DSS axles!
Old 01-14-2003, 02:22 AM
would any cf hood create enough clearance?
Old 01-14-2003, 02:13 PM
jacobyb's Avatar
Sure. You just have to make sure that it has a slight "buldge" in it, and there are plenty out there that do. Just don't get anything with a ricey cowl induction or something like that.
Old 01-14-2003, 08:58 PM
poison's Avatar
Default Re: My H22A Civic Coupe Suspension Problem (jacobyb)
You're right...that is funny...
Hard to believe the H22 flexing in a Civic engine bay when the majority of H22 Civic have race mounts with BARELY any flex.
You will not need a 'custom' hood or anything for fitting the H22, ESPECIALLY with HASport mounts.
SpoolnEG6
08-09-2010 03:43 PM
75stroppe
Honda Civic (2001 - 2005)
07-23-2008 03:45 PM
dj626
06-30-2005 07:21 PM
Type Goch
08-28-2001 02:27 PM
Quick Reply: My H22A Civic Coupe Suspension Problem (HELP!?!?)
