Temp Problem
Temp Problem
Okay I know the cause of my problem what I want to know is has anyone had this problem if so what did you do to solve it. Stock 93 civic si replaced the radiator 6 months ago with a dual thickness aluminium unit. The car runs great no overheating issues. Now that winter is here I have the problem of it running to cool. This makes it hard to get the car warm inside. I thought about running a higher temp tstat but that is only going to help with warm up not so much keeping the temp up. The other thought I had was blocking off a portion of the rad to effect its cooling ability
The T-stats job is to keep the water jacket around the engine at a specified temperature. If your radiator has the capacity to overcool, the T-stat should be able to restrict the flow and maintain the desired temperature. Are you sure the current T-stat is functioning properly?
cbr_ryder
Classic Hondas
16
07-28-2023 07:13 AM
cbr_ryder
Classic Hondas
01-06-2022 05:47 PM
