LS/Vtec
Old Mar 11, 2006 | 12:04 AM
DohctorVtec's Avatar
Default LS/Vtec
Hey guys I searched but really couldnt find anything on this...Im about to do my first LS/Vtec. I am gonna buy the Golden Eagle Vtec Conversion System. and use my B18A1 Block with my B16 head. Anyways . I want to know how hard it is... Im pretty knowledgeable on cars and doing things just want to get the scoop / lowdown on an LS vtec any advice / tips would be much appreciated.
Old Mar 11, 2006 | 01:23 AM
crxnj's Avatar
Default Re: LS/Vtec (DoctorVtec)
Heres some tips..
Use gsr oil and water pump and get arp rod bolts..And spray that GE headgasket with some copper spray..
Its not very hard to do when you have a kit like that from GE that has everything you need..You dont even have to take it to the machine shop anymore like back in the day..
Old Mar 11, 2006 | 07:51 AM
saleensolution's Avatar
Default Re: LS/Vtec (Mr.speaker)
make sure they are gsr studs b16 are to short. if you use the gsr water pump you will have to use the gsr timimg belt as well.
Old Mar 11, 2006 | 07:58 AM
Default Re: LS/Vtec (saleensolution)
Yeah it is a b16 head anyone got a price idea on gsr waterpump and arp studs?
Old Mar 11, 2006 | 01:07 PM
Ok question friend of mine just told me GL reving over 6500 with a stock LS bottom end then another told me 7600 is safe with ARP rod bolts or just upgrade pistons / rods?
Old Mar 11, 2006 | 06:18 PM
Default Re: LS/Vtec (DOHCtor Vtec)
Bump for help
Old Mar 11, 2006 | 10:29 PM
crxnj's Avatar
With stock rod bolts you can rev to 8000+ rpm but have a good chance of stretching the rod bolts..Getting the arp rod bolts you can rev high safetly,,Theres always chance of something going wrong though when revving high..
Like I said get arp rod bolts,gsr oil and water pump and you'll be fine..If you have the money you can always balance the rotating assemby..
Old Mar 13, 2006 | 09:26 AM
DJ Gurgla GSR's Avatar
Lots of Ls/Vtec info on this site http://www.hondaswap.com/forums/index.php
pssst.... check my sig too
Old Mar 13, 2006 | 09:09 PM
Rukusmasta2's Avatar
Default Re: LS/Vtec (DJ Gurgla GSR)
https://honda-tech.com/zerothread?id=1119323
https://honda-tech.com/zerothread?id=1082172
https://honda-tech.com/zerothread?id=1083788
https://honda-tech.com/zerothread?id=501372
https://honda-tech.com/zerothread?id=720621
Most wont be that nice, look aroudn navigate through the site ull find **** like this
Old Mar 13, 2006 | 09:11 PM
Default Re: LS/Vtec (Rukusmasta2)
ive got some PR3 Pistons which are good for bumping up compression on all motor LS/VTEC'S
88dxt
12
Dec 26, 2009 11:53 AM
Streetsport
Feb 2, 2009 02:25 PM
97_coupe
14
Feb 11, 2008 05:37 PM
civicswap
Mar 5, 2005 04:04 PM
blueskiesfade609
Feb 16, 2004 06:11 AM
