replacing an axle and having problems
ok so i have a 95 ex. 2dr
replacing the passengers side axle
i have everything done and am now tightening everything down.
the problem that I'm having is with the ball joint.
first things first
IT IS NOT CROSS THREADED
but the entire stud is spinning when i try to tighten the castle nut down...
any advice
this is a pic that i robed from another post.
but this is what I'm talking about
first things first
any advice
Re: replacing an axle and having problems (95jeremie)
use an extra jack or jackstand under the lower control arm and let the vehicles weight onto it it. try and go as far inboard as you can while staying on the horizontil portion of the control arm so you have room to put your nut on and get a socket in there
Re: replacing an axle and having problems (4do4damsho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4do4damsho »</TD></TR><TR><TD CLASS="quote">do you have a swap in it?</TD></TR></TABLE>
no swap... well d16a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub »</TD></TR><TR><TD CLASS="quote">use an extra jack or jackstand under the lower control arm and let the vehicles weight onto it it. try and go as far inboard as you can while staying on the horizontil portion of the control arm so you have room to put your nut on and get a socket in there</TD></TR></TABLE>
will give it a shot. will be back in 10 min. Thanks
Re: replacing an axle and having problems (nub)
well that didn't work
Another thing to try would be to use a huge pliers (don't know the type name). Use it to clamp down on top of the ball joint and under the control arm to keep it from spinning inside. Edit: A huge heavy-duty C-clamp may also work.
Re: (Endo-land)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endo-land »</TD></TR><TR><TD CLASS="quote">Reconnect the shock fork when you jack up the lower control arm and it should go. Are you using an impact wrench?</TD></TR></TABLE>
the shock fork has the bolt in it but not tight and no I'm not using an inpact wrench... but i do have access to one. just gotta hook up the compressor... well i guess I'll go and do that...
usually what works for me is to jack up the lower control arm, but you said that didn't work, how high did you jack it?
also try some sort of lube on the nut and try to spin it faster, may sound silly but that usually works for me.
Re: replacing an axle and having problems (b18_ef_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_ef_hatch »</TD></TR><TR><TD CLASS="quote">Another thing to try would be to use a huge pliers (don't know the type name). Use it to clamp down on top of the ball joint and under the control arm to keep it from spinning inside. Edit: A huge heavy-duty C-clamp may also work.</TD></TR></TABLE>
i have a C-clamp that i will give a shot after the inpact wrench.
thanks everyone
thanks everyone
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">usually what works for me is to jack up the lower control arm, but you said that didn't work, how high did you jack it?
also try some sort of lube on the nut and try to spin it faster, may sound silly but that usually works for me.</TD></TR></TABLE>
car was 1/4" off the jack stand
Re: (Endo-land)
Inpact wrench got it! H-T is the ****
thanks everyone
Jeremie
thanks everyone
Jeremie
Re: (95jeremie)
FIXED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie »</TD></TR><TR><TD CLASS="quote">
Inpact wrench got it! Impact Wrench is the ****
thanks everyone
Jeremie</TD></TR></TABLE>
thanks everyone
erikiksaz1
Suspension & Brakes
11-02-2008 05:10 PM
