LS swap in a 99 SI?
Old Mar 12, 2004 | 02:48 PM
gsrhatch530's Avatar
Default LS swap in a 99 SI?
I want to put a 98 B18b long block into my SI. It is obd2a but comes with a obd1 ecu. I have the obd2b ecu conversion harness. What will I have to modify to make this work.
I need to get the car running asap and this is what I can aford right now. My b16a2 is out of commission.
Old Mar 13, 2004 | 08:15 AM
Sohc Driver's Avatar
Default Re: LS swap in a 99 SI? (gsrhatch530)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch530 &raquo;</TD></TR><TR><TD CLASS="quote">I want to put a 98 B18b long block into my SI. It is obd2a but comes with a obd1 ecu. I have the obd2b ecu conversion harness. What will I have to modify to make this work.
I need to get the car running asap and this is what I can aford right now. My b16a2 is out of commission.</TD></TR></TABLE>
There shouldn't be any problems...if you already have the obd2b ecu conversion harness then its all plug and play. The extra sensors that come witht he obd2a motor won't matter since your obd1 ecu won't recognize that they are there. Plug and Play YO!!!
Khoi
xXxHOLYMANxXx
Jul 19, 2012 03:39 PM
big-cat
26
Oct 19, 2006 11:14 AM
kyden
Nov 19, 2004 10:45 PM
Malachi_
14
Sep 25, 2003 04:12 PM
sshaikh01
Mar 22, 2003 07:10 AM
