LS swap
I bought a b18b1 swap to go in my 95 honda civic dx coupe. However the swap does not have a starter, alternator, shift linkage, or mounts. Can i use any of these parts off of the d15 in the car now for the swap or do i need to buy these parts for the b18b1. Any other information or problems i might run into while doing this swap would be highly appreciated.
Thanks Josh
Thanks Josh
So basically all you've got is the engine?
No, No, No, Yes.
You'll need b series parts for those.
Check http://tech.hybridgarage.com/tech/index.html
No, No, No, Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsjm5 »</TD></TR><TR><TD CLASS="quote">starter</TD></TR></TABLE>
94-01 Integra Starter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsjm5 »</TD></TR><TR><TD CLASS="quote">alternator</TD></TR></TABLE>
92-95 Integra Alternator (for full plug and play)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsjm5 »</TD></TR><TR><TD CLASS="quote">shift linkage</TD></TR></TABLE>
94-01 Integra Shift Linkage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsjm5 »</TD></TR><TR><TD CLASS="quote">mounts</TD></TR></TABLE>
You can reuse your stock upper tranny mount, the remaining brackets and mounts need to be from a 94-01 Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamsjm5 »</TD></TR><TR><TD CLASS="quote">Does it matter if it is a LS or a GSR? Are the parts interchangeable?</TD></TR></TABLE>
It doesn't matter.
It doesn't matter.
