Back engine mount, need Help asap
Old Jan 3, 2005 | 12:16 PM
k24a4kid's Avatar
I'm a Jackass
Default Back engine mount, need Help asap
Sorry would try lookin but search is down.
My friend is buting a ls in his 95 civic and his back mount is too short. What mount should he use. He tryed the stock d series, ls, and b16 and none of them worked.
The block is a 93 with a 00 b16 trans goin into a 95 civic
Old Jan 3, 2005 | 06:06 PM
Bartman201's Avatar
Default Re: Back engine mount, need Help asap (b20turbocoupe)
the Ls mount should work. i did that swap and it worked fine. check again.
Old Jan 3, 2005 | 06:14 PM
slomofo's Avatar
GDD Member
The back mount? Or the L-Bracket? Try 99 Si bracket and any b-series mount.
k24a4kid's Avatar
I'm a Jackass
Default Re: Back engine mount, need Help asap (Bartman201)
ok , but did you use the mount and the bracket from the ls or just the braket?
Old Jan 3, 2005 | 06:22 PM
k24a4kid's Avatar
I'm a Jackass
the back mount and the braket, we tryed to use the d series mount and the other brackets, none worked. so should we try useing the ls mount and the bracket? He wants to make sure it's goin to work first before trying it. He got no time with school and work.
Old Jan 3, 2005 | 07:08 PM
MugenRacerX's Avatar
B series mounts are needed the sohc mounts do not work,doing this swap this week end.
94b18b into 92eg civic this swap should be about simple as they get.
Old Jan 4, 2005 | 04:19 AM
k24a4kid's Avatar
I'm a Jackass
Default Re: (MugenRacerX)
i did the swap before but we used the d series mount and ls braket, but we used the ls engine mount and it sat on a little angle, this time we used the gsr and the bracket wouldn't reach. We'll try after school if it isn't raining
Old Jan 4, 2005 | 01:37 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (turbofienD 04)
it"s the samething, if he got a gsr mount would that work??
Old Jan 5, 2005 | 04:41 PM
gsr/rs/ls/gs all the same itr is the same but harder bushing in the mounts and missing the lowwer tranny mount altogether.
atleast-3
Sep 23, 2007 12:07 AM
b17turbo
15
Jun 7, 2006 02:33 PM
chuckieD
Dec 4, 2005 11:02 PM
k24a4kid
Jan 5, 2005 11:02 AM
HondaGSR
Jul 22, 2003 11:01 AM
