LS rods in a d16???? help
Old Aug 10, 2006 | 02:13 PM
Das Bar 2k4's Avatar
Default LS rods in a d16???? help
I've heard of ppl using ls rods in d16 block i'm trying to find more info and b4 everyone starts the flames i did a search and got nothing just seeing if anyone has any info bc i'm looking to rebuild for more boost and don't want to spend a lot of money on my daily car. just want more boost for daily and save my money for my S i'm pickin up.
thanks in advance,
Greg.
Old Aug 10, 2006 | 07:24 PM
vsmhatched's Avatar
Default Re: LS rods in a d16???? help (Das Bar 2k4)
dang, i'd like to know
Old Aug 10, 2006 | 11:06 PM
Default Re: LS rods in a d16???? help (GreyDel)
nobody has heard about this?
Old Aug 11, 2006 | 08:30 AM
unknown0001's Avatar
Yes you can do this... You have to notch I belive either side of the rods so that they will clear the rod journals or something along those lines.
I have had a friend do it and he liked it...till his engine failed due to the wrist pin comming out by itself while the engine was running.
do a search...people do it but I would rather just get aftermarket rods to be safe then sorry
http://www.homemadeturbo.com/f...396.0
Old Aug 11, 2006 | 09:58 AM
Default Re: LS rods in a d16???? help (Mr.RHTuner)
thanks that's what i was really wondering how durable that setup was.
Old Aug 11, 2006 | 10:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Bar 2k4 &raquo;</TD></TR><TR><TD CLASS="quote">thanks that's what i was really wondering how durable that setup was.</TD></TR></TABLE>
some d-series turbo guys install the suzuki vitara pistons and either aftermarket rods or they get LS rods shot-peened and machined to fit.
My friend did it and it was a failure because he made his own piston wrist pin or had it machined to fit.
I'm sure if you calculate everything, it will work fine but as I said, the time and the machining to go into it, I'd just get aftermarket rods for your specific application.
adam00
Welding / Fabrication
24
Dec 31, 2009 01:25 PM
Weston
Oct 15, 2006 09:17 AM
yellowjdmcrx
11
Oct 8, 2006 09:24 AM
wrXtian
Aug 2, 2003 05:31 PM
Hybrid
Feb 28, 2002 09:28 AM
