LS Rods in a D16.
Old Feb 27, 2002 | 02:47 AM
Hybrid's Avatar
Default LS Rods in a D16.
Is there anyone using LS (B18B) rods in their D16's?
Old Feb 27, 2002 | 05:54 AM
b18bturbo's Avatar
Default Re: LS Rods in a D16. (Hybrid)
it works just put it that way. Alot of guys who dont want to go all out on there d16 do it as cheap alternative.
Old Feb 27, 2002 | 06:14 AM
JaeOne3345's Avatar
Default Re: LS Rods in a D16. (b18bturbo)
for the cost of the rods and machine work..migh as well just save a measily 200 bucks more and get some of the cheaper rods on the market ..they will be fine on low boost.
Old Feb 27, 2002 | 06:20 AM
DSF's Avatar
DSF
Default Re: LS Rods in a D16. (JaeOne3345)
Well, my LS rods cost me $75 and the machining cost $80. I'd be hard pressed to find an deal like that going aftermarket. Now I just have to assemble the shortblock. Too bad it's like the 3rd engine down on my list to complete
Old Feb 27, 2002 | 07:24 AM
Hybrid's Avatar
Default Re: LS Rods in a D16. (DSF)
well thats it. if I'm going to buy a cheaper rod for low psi then I'll just keep my D16 rods. I know guy's running 10 PSI on those suckers with no problems. but I've also seen all four rods twist off right off just above the crank and rip through the block and crank girdle.
anyway how much boost would those LS be good for on a D16 block?
Does anybody have pictures of both?
Old Feb 27, 2002 | 12:47 PM
Smashback's Avatar
Import Tuner said they are good for like 300 HP. I may do the same thing come rebuild time since that's about all I'm shooting for.
Old Feb 28, 2002 | 04:41 AM
Hybrid's Avatar
Default Re: LS Rods in a D16. (mplex2000)
300 hp hey? that sounds like more that my sohc will reach.
anyone else?
Old Feb 28, 2002 | 05:16 AM
Smashback's Avatar
Crank up that boost!!! Why build it if you're not running more than 15 lbs of boost
Old Feb 28, 2002 | 05:56 AM
VTC_CiViC's Avatar
$300 on a set of Eagles which can handle 400whp+.. why skimp on the important things
Old Feb 28, 2002 | 09:28 AM
TurboSedan's Avatar
New User
Default Re: LS Rods in a D16. (VTC_CiViC)
If the motor is tuned correctly, the rods will not be at too much risk. If it is not tuned well and there is detonation, that is when you have to worry.
adam00
Welding / Fabrication
24
Dec 31, 2009 01:25 PM
Rease3
May 28, 2009 10:57 AM
yellowjdmcrx
11
Oct 8, 2006 09:24 AM
Pfieff
Mar 26, 2004 07:24 AM
Josho_17
13
Mar 18, 2003 03:06 AM
