LS motor with CTR pistons
Old 07-13-2002, 10:44 AM
Gong Show's Avatar
Default LS motor with CTR pistons
Any body here ever run this set-up or know of anybody that has ran this set-up?
CTR pistons(81.25mm)with a OEM 3-layer gasket ran with cower cams. Acorrding to Bojangs site the compression will be 11.69
http://www.bojangs.com/calculator/
The question at hand, are there any type of clearance problems once your start tuning timing and cam gears?
TIA
[Modified by GONG SHOW, 1:46 PM 7/13/2002]
Old 07-13-2002, 02:08 PM
Rembrant Q. Einstein's Avatar
Default Re: LS motor with CTR pistons (GONG SHOW)
You can double check it on http://www.c-speedracing.com . They have a CR calculator in the upper right corner of the main page.
By the way change your signature. Bold Caps are annoying.
Old 07-13-2002, 05:06 PM
Gong Show's Avatar
Default Re: LS motor with CTR pistons (Rembrant Q. Einstein)
yeah, i know about the C-Speed clac. too, but some said that one seemed off a little. But thatnks anyway..
And change my sig, let me think about that one........
NO The mods and nobody else seems to have a problem with it so why should you????
Old 07-14-2002, 03:03 AM
nwarp's Avatar
my friend HAD that setup until he blew his motor, the shop he took it to milled his head 30thous, which he didnt ask for...way to much compression.
if you run ctr pistons in ls block you'll have to retard the timing
Old 07-14-2002, 07:46 AM
Gong Show's Avatar
Default Re: LS motor with CTR pistons (NA DC2)
Damn, thats messed up bro... Is he going to get anything out of it since the shop screwed him?
But yeah, I just wanna know how reliable it will be? And if theres any clearance problems after tuning? IM really considering this build up in a 4th gen hatch or crx or Maybe a 6th gen hatch.
Thanks for info bro.
Old 07-14-2002, 09:52 AM
RedlinedVTEC's Avatar
Yeah I had a machine shop mill my head 40 thousandths (the service limit) without asking. I'm also running CTR pistons, but in a b16a so the compression is only around 11.6:1 after the milling.
Old 07-15-2002, 09:49 PM
Gong Show's Avatar
Default Re: LS motor with CTR pistons (RedlinedVTEC)
3s1k
05-28-2010 04:15 PM
onewayoutcity
05-25-2009 01:06 PM
Top Ramen
10-31-2005 03:06 PM
Mr HYDE
03-22-2004 07:20 PM
X2BOARD
08-09-2001 11:00 PM
Quick Reply: LS motor with CTR pistons
