which crank is better for boost
Old Jan 24, 2008 | 01:31 PM
94dc2's Avatar
Default which crank is better for boost
im building a motor but im not 100% sure which crank would be best for boost i wanted to run an itr crank, but i have herd of people running gsr cranks and ls cranks so i was a little confused on which would be best, by the way its going in a b18c
Old Jan 24, 2008 | 01:45 PM
Schister66's Avatar
Man U FTW
The LS crank will give a little bit more displacement since it has a longer stroke. I'm not sure on the ITR though...
Old Jan 24, 2008 | 01:51 PM
94dc2's Avatar
Default Re: (Schister66)
my last two cars had an itr in them but i didnt know if i could make more power, or my reliablity on a different one
Old Jan 24, 2008 | 02:38 PM
DA_HONDA_BOY's Avatar
Default Re: (94dc2)
gsr and itr cranks are the same stroke at 87.2mm and the ls crank is a 89mm stroke if you use the ls crank you need to use ls rods
Old Jan 24, 2008 | 02:43 PM
vestalfootball72
Guest
Posts: n/a
Default Re: (DA_HONDA_BOY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_HONDA_BOY &raquo;</TD></TR><TR><TD CLASS="quote">gsr and itr cranks are the same stroke at 87.2mm and the ls crank is a 89mm stroke if you use the ls crank you need to use ls rods</TD></TR></TABLE>
and get rid of teh oil squirters-- I just read evans tuning posting about the ls being better-- i think he said "theres no reason not to"
Old Jan 24, 2008 | 03:11 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (vestalfootball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">
if you already have rods thats reason enough.
but if you need a crank and dont have rods, do the ls.
thegeezerkid
Nov 12, 2008 10:23 AM
hondamann_p28
Dec 20, 2003 09:25 PM
88hondahatch
Jul 15, 2003 07:03 AM
GokuSSJ4
Mar 5, 2002 01:40 PM
