Longblock plus ???
Old Aug 17, 2003 | 05:17 PM
sledgehammer's Avatar
Default Longblock plus ???
After purchasing a longblock, more specifically a b20z, what else is needed to get it in the car and running besides a tranny?
Modified by sledgehammer at 10:48 AM 8/20/2003
Old Aug 17, 2003 | 06:58 PM
VTECVillain's Avatar
Default Re: Longblock plus ??? (sledgehammer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sledgehammer &raquo;</TD></TR><TR><TD CLASS="quote">After purchasing a longblock, more specifically a b20z, what else is needed to get it in the car and running besides a tranny?</TD></TR></TABLE>
It would help to know what car this is going into before anyone could tell you what other parts you would need. For all we know we could assume you are going to install it into a 1982 Ford Escort...
Old Aug 18, 2003 | 05:13 PM
Default Re: Longblock plus ??? (VTECVillain)
It doesn't really matter what car it's going into, I just wanted to know what else I would need to make it a complete functioning engine. But say it was going into a '99 civic coupe if that helps?
Old Aug 18, 2003 | 05:44 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sledgehammer &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't really matter what car it's going into, I just wanted to know what else I would need to make it a complete functioning engine. But say it was going into a '99 civic coupe if that helps?</TD></TR></TABLE>
Uhh, it does matter what car it's going into.
You'll need intake manifold/throttle body, exhaust header, distributor, fuel injectors, fuel rail, tranny, axles, ECU.
Old Aug 18, 2003 | 08:13 PM
Default Re: Longblock plus ??? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
Uhh, it does matter what car it's going into.</TD></TR></TABLE>
Well if it really did matter what car it was going into, why didn't you tell me to get a LS IM, B series axles, and a P75 ECU? The general answer you gave me was exactly what I was looking for though. I appreciate that. But a Longblock should include the Intake manifold, Exhaust manifold, distributor, fuel rail and injectors. So, after the longblock I'll need the tranny, axles and ECU?? is that all?
Mike
Old Aug 18, 2003 | 08:19 PM
poison's Avatar
The actual components don't matter, but things like different OBD type fuel injectors, wiring harness and OBD distributor will determine what you will need.
For example, if you have a 97 hatch, if someone suggested a distributor, that is correct. However, more into detail, you would need a 96-00 distributor (being OBD2), and not an OBD1 distributor.
But, that would be all.
Old Aug 18, 2003 | 08:34 PM
Thanks for helping me out...
The only reason I didnt need to go into much detail is because right now I'm still looking into different setups.
Mike
Old Aug 18, 2003 | 08:46 PM
poison's Avatar
NP man
H-powerd
Jul 15, 2007 08:34 AM
130R
Jan 14, 2005 05:53 PM
PM-Performance
May 20, 2004 11:23 AM
sleepyhamsterlx
11
Mar 27, 2004 12:56 PM
Timmay
Jul 21, 2003 01:06 AM
