keeping my A/C.....how?
Old Feb 19, 2003 | 06:41 AM
wm5holla's Avatar
Default keeping my A/C.....how?
how do u keep ur ac when ur doing a swap? i mean like why do people lose their AC?
Old Feb 19, 2003 | 09:36 AM
Trey's Avatar
25 Year Member
Default Re: keeping my A/C.....how? (wm5holla)
Some people don't want the weight, some are too cheap to do it right.
All you need it the correct bracket and your AC compressor will bolt to the bracket and it will bolt to the block.
What car and engine do you have? Year?
Old Feb 19, 2003 | 10:10 AM
93civEJ1's Avatar
yeah i am interested in this too...will be doing a swap soon in my 93 ex and am using the b16 block...can i use the d16 bracket or have to get a b-series bracket? but i can use my stock compressor? right?.....how hard is this do to? school me!
Old Feb 19, 2003 | 10:49 AM
wm5holla's Avatar
Default Re: keeping my A/C.....how? (93civEJ1)
yea school us both.. how much weight is loss from no ac ??
Old Feb 19, 2003 | 11:03 AM
fowler!'s Avatar
Prolly a little bit less than 20lbs. That compressor is heavy.
Also, one less belt equals less stress on the motor.
Old Feb 19, 2003 | 11:27 AM
93civEJ1's Avatar
Default Re: keeping my A/C.....how? (fowler)
yeah but i prefer to keep mine...can anyone answer my question for me??? thanks alot
Old Feb 19, 2003 | 04:40 PM
VXdreamer's Avatar
If you are going from an SOHC to the DOHC implant, you'll want the DelSol VTEC ac bracket, its stamped with a P54. It allows you to use your AC comp on the fresh swap.
Old Feb 20, 2003 | 05:05 AM
VTECVillain's Avatar
Default Re: keeping my A/C.....how? (Trey)
I who am both too cheap and too lazy to put mine back.
Old Feb 20, 2003 | 05:56 AM
93civEJ1's Avatar
Default Re: keeping my A/C.....how? (VTECVillain)
kool deal...so will the p54 work on any b-series block?
Old Feb 20, 2003 | 10:39 AM
ErikDaGenErik's Avatar
what about keeping a/c on an '99 hatch with h22? i have a '94 coupe with an h22 but the car never came with a/c. my hatch does. how do i keep it? who sells mounts that enable me to do so.
Old Feb 21, 2003 | 03:37 AM
wm5holla's Avatar
Default Re: keeping my A/C.....how? (ErikDaGenErik)
can u use a gsr or si ac bracket?
Old Feb 21, 2003 | 03:43 AM
Trey's Avatar
25 Year Member
You need the ac bracket with a P54 stamped on it. Mine was from a 99-00 Si and had the P54 stamp but now the 96+ del Sol is the bracket you need to get (it has the P54 stamp now).
You can't use the gsr bracket since the teg uses a different ac compressor (mounts differently).
Old Feb 21, 2003 | 05:00 AM
wm5holla's Avatar
thanxs!!!
Old Sep 13, 2003 | 03:49 PM
wm5holla's Avatar
Default Re: keeping my A/C.....how? (VXdreamer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VXdreamer &raquo;</TD></TR><TR><TD CLASS="quote">If you are going from an SOHC to the DOHC implant, you'll want the DelSol VTEC ac bracket, its stamped with a P54. It allows you to use your AC comp on the fresh swap.</TD></TR></TABLE> what mount do u need for a 92-95 ac on a 94+ motor?
Old Sep 13, 2003 | 03:52 PM
wm5holla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> i fi had a 94 ac i would need a 94 ac mount? if i hada 92-95 ac i would need a P54 mount?
Old Sep 15, 2003 | 05:12 PM
owwwch's Avatar
go to hcp engineering and they have the ac brackets for the h swap....i have two egs w/ the h swaps and still have ac.
Old Sep 15, 2003 | 11:24 PM
scgtam's Avatar
Default Re: keeping my A/C.....how? (owwwch)
just want to make sure. if i have a eg putting in B engine. i need del sol vtec ac (p54)bracket right?
Old Sep 16, 2003 | 08:45 AM
wm5holla's Avatar
Default Re: keeping my A/C.....how? (SCG)
what mount or bracket do u need a 94-00 AC compresser on a b18?
kenji
Nov 2, 2010 12:35 AM
Jap_Spec_Imports
Mar 15, 2009 01:13 PM
DetainedCivic
Jul 17, 2006 04:54 PM
kenji
Dec 3, 2002 03:38 PM
kenji
15
Dec 3, 2002 02:28 AM
