WTF is wrong w/my Gsr swap? HELP!!!
when driving at steady RPM's(3k,4k...etc) my car has this shudder to it...it feels like its missing while driving...and also...my lights dim and brighten also...someone help me figure this out!
your lights dimming and brightening sounds like an alternator problem.....go have it checked at schucks. they do it for free. as far as your motor
1.check yout timing
2.check your plugs, they may be fouled out
3.check your cap rotor/test ohms from your plug wires.
1.check yout timing
Re: (Zerob16eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zerob16eg »</TD></TR><TR><TD CLASS="quote">your lights dimming and brightening sounds like an alternator problem.....go have it checked at schucks. they do it for free. as far as your motor
1.check yout timing
1.check yout timing
Re: (slowazzhatch)
i put new plugs in and fuel filter...timing is correct as far as i can see...i never touched the crank/cam gears...the distributor is set centered on the slots...
do i have to take out the alternator to have it checked?
Re: (SwapWhore101)
you don't have to take it out, you can just bring your car there and they'll bring out a hand held tester to check out your charging system.
Lookincrazy
05-15-2003 01:50 AM
