JDM sohc vtec problems???
Old May 13, 2003 | 04:07 PM
J2turbo21's Avatar
Default JDM sohc vtec problems???
To start off I already did a search and i didnt find anything.
Ok well this guy i know has a 93 civic hb CX and he put a D15 sohc vtec motor in it and is using a PO8 ecu.He said it runs but he thought it was a drop in plug and play kinda thing.I was wondering what kind of wiring needs to be done for it to work right.
Also he said something about still using the CX header which has the cat on the front of it with the 1 wire O2 sensor,does this have to be changed out?
Old May 18, 2003 | 05:03 PM
J2turbo21's Avatar
Default Re: JDM sohc vtec problems??? (J2turbo21)
Anyone?
Old May 19, 2003 | 11:58 AM
USDMMARK's Avatar
^^shrugs^^
but arent you glad i replyed so you don't feel alone
Old May 19, 2003 | 04:12 PM
J2turbo21's Avatar
Default Re: JDM sohc vtec problems??? (no-tec)
HEHE thanks
Old May 19, 2003 | 06:01 PM
eg6ajk's Avatar
no P08 uses a single wire 02, just like the CX so no need to mod anything there.
But you'll need to add vtec solenoid wire and vtec oil pressure wire to the ecu. as well as adding the ground to the oil pressure switch.
check the diagram (just the two I mentioned)
Straits514
Feb 15, 2011 08:07 PM
1995civicEJ
Oct 1, 2006 11:15 AM
kkitzman
Jan 5, 2006 05:31 PM
mxer518
May 8, 2005 03:00 AM
Touch
Feb 11, 2003 10:29 AM
