C&R radiator fan motor does not connect to '92 CX?!
I was installing a C&R radiator to my '92 CX.
When I tried to hook up the fan motor to my wire harness, it wan't even close!
the wire harness had "II" looking conector and C&R had "-I" looking connector.
How can I make these fit? Also, the size of the connectors are all same. NO male, female match.
Another thing. The hose connectors seems like it's bigger diameter than the stock hose.
Re: C&R radiator fan motor does not connect to '92 CX?! (VWkila)
Anybody?
Anyways, I have some dimentions.
C&R Radiator neck ins one and 1/4 inches thinck in OutsideDiameter.
thermostat housing cover neck is one and 1/8 inches thick.
So it does not match.
[Modified by VWkila, 6:34 PM 9/22/2002]
New User
I have the same radiator and fan from C&R, basicaly just take the old fan harness, cut that off, then cut of the one on the C&R fan and connect the stock on with some crimps or whatever using the old stock harness. After that you should be good to go. The spal fan that comes with the C&R fan is a universal fan. I figure they use it to keep cost down. Its still a good price for the money. Good luck
jeremyrocksursox
10-01-2009 07:43 AM
AgentJam
07-01-2005 05:23 AM
no2unenolife
03-10-2005 06:28 PM
fathergoose
10
06-09-2003 10:53 AM
