jdm b18c difference between manual and auto
Old Feb 18, 2006 | 11:57 PM
acerz007's Avatar
Default jdm b18c difference between manual and auto
Starters:
What's the difference between a b18c(manual) compared to a b18c(auto).
Things I've found out (true or false):
1) Intake mani is different between the 2 engines;
2) camshaft and crankshaft is different;
3) idle problem if engine is originally auto then switched to manual
4) ECU is different
Any info would be greatly appreciated
Thanks in advance
Peter
PS: this is goin' on an EG h/b. anything else that's needed to make it work?
Modified by acerz007 at 9:26 AM 2/19/2006
Old Feb 20, 2006 | 12:08 PM
daver's Avatar
Default Re: jdm b18c difference between manual and auto (acerz007)
well i know that the auto gsr redlines at only 7600rpms. So that would definately indicate the ecu and its maps, and quite likely the cams as well. Don't know if they bothered changing the intake mani tho.
d
G a b e
Apr 8, 2005 08:04 PM
Tad
20
Jun 5, 2004 01:11 PM
Quade
Oct 5, 2003 11:27 AM
CrxSi10
Jan 15, 2002 09:51 AM
