Is the ITR engine a direct bolt in for ek?
Old May 15, 2004 | 07:13 PM
97mini-me's Avatar
Default Is the ITR engine a direct bolt in for ek? (searched...and searched)
I am buying an itr engine for my ek, well, actually ej hatch. Is this pretty much a direct bolt in? If this isn't the right place to post this, forgive me, I figured someone with an itr might know. What will I need to make it work. Any help is appreciated!
Modified by 97mini-me at 8:33 PM 5/15/2004
Old May 15, 2004 | 07:23 PM
HypeR0070's Avatar
Default Re: Is the ITR engine a direct bolt in for ek? (97mini-me)
Search. there's alot of articles in hybrid forums
Old May 15, 2004 | 07:42 PM
97mini-me's Avatar
Default Re: Is the ITR engine a direct bolt in for ek? (HypeR0070)
I've searched under everything I can think of. I haven't found anything. I wouldn't post unless I've searched. I know there are people that do, but I'm not one of them. I really need to know this. Ordering engine on monday, putting it in in like 2-3 weeks. I want to have all the parts readily available so I can drop and go. If there are any other parts you can think of that I will need, let me know. Thanks
Old May 15, 2004 | 08:24 PM
brian g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97mini-me &raquo;</TD></TR><TR><TD CLASS="quote">I am buying an itr engine for my ek, well, actually ej hatch. Is this pretty much a direct bolt in?
Almost, you'll need a few parts from a 99 Si. Like left-hand engine bracket, rear bracket. You'll also need the front transmission bracket if your engine doesn't have one and an AC bracket but I forget what year.
Old May 15, 2004 | 09:01 PM
Turbogixxer's Avatar
Default Re: Is the ITR engine a direct bolt in for ek? (brian g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g &raquo;</TD></TR><TR><TD CLASS="quote">an AC bracket but I forget what year.</TD></TR></TABLE>
A Del Sol DOHC VTEC (P54) a/c mount and he will have to reuse his sohc a/c compressor
Old May 15, 2004 | 09:50 PM
brian g's Avatar
Default Re: Is the ITR engine a direct bolt in for ek? (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
A Del Sol DOHC VTEC (P54) a/c mount and he will have to reuse his sohc a/c compressor</TD></TR></TABLE>
Yeah, but they're different 94-95 and 96-97. Which year is it?
brian g
Old May 16, 2004 | 01:50 AM
kivi85's Avatar
I´m looking into the same subject and this cleared a lot for me.
http://www.phear7imports.net/s...6gen/
I have understood everything ecxept the secondary 02 sensor.
Does that mean that there is a second 02 sensor on the exhaust after the the cat?
and also the thing whit the drivers side mount. In the site above he says you have to buy an drivers side mount from civic si 99-00 but here it says that you uses your old civic mount?
http://hybrid2.honda-perf.org/tech/6gmatt.html
Old May 16, 2004 | 07:06 AM
brian g</TD></TR></TABLE>
I have always used OBD1 (94-95 with no problem but I have had people use 96-97 with no problems) (i do not have first experience with 96-97)
I have also used CRV a/c mount and it is the same (most are marked P54 and some are P30)
Old May 16, 2004 | 01:31 PM
brian g's Avatar
Default Re: Is the ITR engine a direct bolt in for ek? (kivi85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kivi85 &raquo;</TD></TR><TR><TD CLASS="quote">I´m looking into the same subject and this cleared a lot for me.
http://hybrid2.honda-perf.org/tech/6gmatt.html</TD></TR></TABLE>
Yes there is an second O2 sensor but it's in the cat. Unless it's a JDM ITR, then there's no secondary O2
It's the driver-side bracket not mount.
brian g
Old May 16, 2004 | 02:30 PM
kivi85's Avatar
well it just happends that I´m buying a 98 jdm itr swap so that good news for me that there is no secondary o2. less wiring to be done
Old May 16, 2004 | 03:34 PM
97mini-me's Avatar
That article helped me out alot! Thanks man. So I need a couple of mounts, and since I have the ex wire harness all I will have to do is extend a few wires and I should be alright? Thanks again. If anyone has anything else, POST!
EDIT: Nevermind, it is in the post above. (Kicking self in ***)
Modified by 97mini-me at 7:35 PM 6/2/2004
kakahoya
19
Aug 21, 2007 07:02 PM
{Powered by VIII}
Mar 19, 2004 01:00 AM
SoCaLNaTIvE
Feb 18, 2004 07:40 AM
